RaceCapturePro TelemetryQuickstart
Revision as of 05:49, 8 May 2013 by Brentp (talk | contribs)
Unboxing Getting a SIM card Installing SIM card Connecting Telemetry Module to Race Capture Connect GPS to RaceCapture Connecting Antenna Creating RCLive account & get device Id Install RA Configuring RaceCapture/Pro Setting channel sample rates Sample Rate Recommendations GPS 1Hz -5Hz Accelerometer 5Hz Other sensors (links to sensor configurations) Set device id Write configuration Power cycle RCP Connect to real power source (NOT USB) or connect to powered USB Hub with extra juice eg: http://www.amazon.com/Sabrent-Powered-adapter-compatible-HB-USB30/dp/B00BJPRI1Y/ref=sr_1_3?ie=UTF8&qid=1367991516&sr=8-3&keywords=usb+hub+high+power http://www.amazon.com/D-Link-DUB-H7-High-Speed-7-Port/dp/B00008VFAF/ref=sr_1_5?ie=UTF8&qid=1367991578&sr=8-5&keywords=usb+hub+high+power Watch LEDs on telemetry device explain / document LED flashing Press log button Got to race-capture.com/home, look for a new event, click on it View your live telemetry! Race faster!
1) Configure -- This means downloading RA, connecting RCP to it and configuring at least the basic stuff (gps, accel, speed, remote server IP & serial #) BRENT: does RA & RCP understand hostnames and will we give users a serial #? If it doesn't understand hostnames we need to make some adjustments in AWS to setup an elastic IP that won't change. Otherwise it's gonna suck if it does.
  Also means setting up sensor configuration etc, probably not worth going over in quickstart.
2) Signup for an account on race-capture.com. Add your device and serial # (website prompts after signup to add one). Once RCP starts logging a race event will be created and you'll see it on the homepages. BRENT can we send Fred a telemetry module? 2) Connect to a 'real' 12v power source in the car (RCP can't power itself, GPS and the telemetry module via usb, trust me, I've tried) 3) Connect GPS & telemetry module 4) Turn on (if not already on). 5) Press log button 6) Watch for LEDs to blink appropriately. BRENT what are the realtime module LEDS status codes? Got those documented anywhere? Quickstart should have a list of what each blink/led means.
RaceCapture Pro Quickstart Guide
Video Quickstart
Race-Capture.com
1. Registration go to http://race-capture.com/ sign up!! (have a good password! If you need one generated and a great way to remember them, lastpass.com. Remember your password, and have a secure one!)
2. Email verification Check your inbox, click where it says to in the email we sent you (just checking that it’s you).
3. Login Do that login thing! (you wrote down your login and password right? good.)
4. Setup your Race unit
5. Spec your car setup 6. Setup your settings (who can see what) 7. Watch a race 8. Sharing a race 9. Sharing your stats.
Race Analyzer
1. Connecting USB to your computer (verifying drivers) 2. Validating SD card 3. Registering your Race Capture Pro 4. The Interface 5. Your first time logging 6. Import the sample file 7. View the Sample Data 8. Analyze the sample data
Race Capture Pro Redbox 1. Registration Completion (did you find the serial number) 2. Connect to your PC 3. Plug it in and go racing 4. Connecting power 5. Connecting the GPS antenna 6. Mounting the unit 7. What the lights mean 8. Pressing the button (what have I done?!) 9. Taking the chip out (or for that matter, putting it in) (yes the SD card, that’s what we meant) 10. Sensors overview 11. Sensors list (suggested, along with online links)
Race Capture Pro Telemetry
1.Registering and connecting your telemetry system 2. Your sim card (where to get it, what you pay, when you use it, where it goes) 3. Mounting 4. Connecting 5. Software connection
Race Capture Pro Bluetooth Transmitter
1. Mounting and connecting the unit 2. Pairing the unit
Race Capture Pro Bluetooth Android Dash App
1. Loading the app from the android play store 2. Logging in 3. Using the dash (the video)
