RaceCapturePro Sensors
Revision as of 00:29, 30 December 2013 by Brentp (talk | contribs) (→Temperature Sensors: added AEM info and calibration)
GM Style fluid sensors
Mfg Pic Pigtail Part Numbers Mechanical Notes
GM
  • Pigtail Pico 5615pt
3/8" NPT threaded brass body and a 2 pin terminal. Can be used for air inlet temperature for normally aspirated engines
GM
  • Pigtail Pico 5616pt
3/8" NPT threaded brass body and a 2 pin terminal. Use for measuring air inlet temperature. Exposed sensing element, necessary for boosted engines where fast response times are necessary. Due to the fragility of the sensing bulb, it is necessary to pot the base of the sensor leads with sensor-safe silicone when used in high vibration environments.
Analog channel configuration
0.37 212.00
0.51 178.00
1.99 104.0
2.47 72.0
4.24 23.0
AEM Sensors
Part # Pic Mechanical Notes
AEM-30-2012 1/8" NPT
0.40 302.00
0.87 239.00
1.88 176.0
3.2 122.0
4.72 32.0
Infrared Tire Temperature
TI Infrared Temperature Sensor samples 3 positions on tire carcass Needs dev board to connect to inputs. Mouser Part #: 595-TMP006AIYZFT Manufacturer Part #: TMP006AIYZFT *Texas Instruments : Board Mount Temperature Sensors Infrared Thermopile Sensor <link to Race Capture digital channel configuration> Can be used for 3 position tire temperature, when mounted within 3" of tire link
Pulse Sensors
Wheel Speed
Pressure Sensors
Fluid Pressure
Tire Pressure
Boost / Vacuum
GM 3.3 bar MAP sensor
  • Sensor: 9373269
  • Pigtail: 88987997
Distance Sensors
Suspension Travel
Angle Sensors
Steering Angle
Throttle Position
Brake Position/Pressure
Linear Sensors
Temperature Sensor
Pullup resistor
  • VDO 323-095, 325-002
Sensor Ground
Pressure Sensors
3 Wire Active Sensors
((picture of active sensor))
Sensor Breakout Board
SensorX
