RaceCapturePro Sensors
GM Style fluid sensors
Mfg Pic Pigtail Part Numbers Mechanical Notes
  • Pigtail Pico 5615pt
3/8" NPT threaded brass body and a 2 pin terminal. Can be used for air inlet temperature for normally aspirated engines
  • Pigtail Pico 5616pt
Analog channel configuration
0.37 212.00
0.51 178.00
1.99 104.0
2.47 72.0
4.24 23.0
AEM Fluid Sensors
Part # Pic Mechanical Notes
AEM-30-2012 AEM-30-2012.jpg 1/8" NPT
0.40 302.00
0.87 239.00
1.88 176.0
3.2 122.0
4.72 32.0
Infrared Temperature
Interface modules for these sensors are in research and development
Image Mfg / Part Description Notes
Mylexis MLX90620.jpg Mylexis MLX90620 16x4 matrix temperature sensor with I2C digital output. The matrix temperature sensor with a 60 degree field of view makes it ideal for a one-sensor tire temperature solution
Thermocouple Sensors
  • Requires the use of a thermocouple amplifier
Soic-8.jpg Analog Devices AD597 Type K Thermocouple amplifier Low cost, easy to use thermocouple amplifier with 10mv/C temperature output directly from a K-Type thermocouple. Ideal for creating a simple thermocouple to 0-5v sensor.
Soic-8.jpg Maxim MAX31851 Thermocouple amplifier Versatile thermocouple amplifier with 1-wire (I2C) digital interface. Ideal for monitoring multiple sensors
Pulse Sensors
Wheel Speed
Pressure Sensors
Fluid Pressure
Boost / Vacuum
  • Sensor: 9373269
  • Pigtail: 88987997
DIY Freescale MPX4250AP 2.5 bar MAP sensor MPX4250ap.png N/A custom custom <link> An extremely popular MAP sensor used in the Megajolt ignition and Megasquirt fuel injection systems. Can build up a simple circuit on perfboard and be powered by 5V v-ref from Race Capture
Tire Pressure
VDO REDI-Sensor™ Multi-Application TPMS Sensors VDOredi.jpg self powered wireless OEM style custom Wireless tire pressure monitoring system link
ASL Ford type throttle position sensor TPMS ensemble.png turnkey unit custom self powered wireless Wireless tire pressure monitoring system includes wireless receiver and gauge link
Distance Sensors
Suspension Travel
Vishay Semiconductors Specialized Optical Switch TCND5000.jpg 3-pin connector Mouser Part #:782-TCND5000 Manufacturer Part #:TCND5000 Optical Switches, Specialized Reflective Sensor w/PIN Photodiode Out <link> Optical distance sensor to be used for pedal travel as well, providing there is a target to sense Link
Angle Sensors
Steering Angle
DIY Sharp GP2D12 optical distance sensor Sensor GP2D12.jpg 3-pin connector GP2D12 custom <link> Optical distance sensor measures from 10 to 80 cm and outputs a voltage corresponding to that distance. To measure suspension travel, install a unit at each corner of car, targeting the road surface. May also be used for pedal travel as well, providing there is a target to sense. Create a target latched to the steering rod and use the travel out and back of the steering rack rod to denote the travel left and right for steering. This measures true steering(and ignores the speed sensitivity of steering systems, showing actual tire angle result, not steering wheel rotation). It also provides a quick way to verify alignment issues as location vs. gps/accelerometer travel in the "Straight ahead" direction will be at varying angles when alignment issues are present.
Throttle Position
ASL Ford type throttle position sensor TPS-45.jpg see pigtail below Standard Motors SMP TH45 equivalent custom Existing style Throttle position sensor available from AutoSport Labs link
ASL Ford type throttle position sensor 5752pt.jpg 3-pin connector fits SMP TH45 above custom Existing style Throttle position sensor available from AutoSport Labs link
Brake Position/Pressure
ATE Brake Fluid Pressure sensor Brakepressuresensor.jpg solder on tabs (2 wire) If your SKU number is 34331150922 than you'll want to reference OE Number 34331150922, 34-33-1-150-922, 80506001237. <link to Race Capture analog channel configuration> threads into T fitting on brake line. Use professional brake fitting tools! link
DIY Freescale MPX4250AP 2.5 bar MAP sensor Brakepressuresensor2.jpg on part ATV type sensor threads into T fitting on brake line. Use professional brake fitting tools! avail at 150psi, or 2000psi, needs 12v supply link
Linear Sensors
Temperature Sensor
Pullup resistor
  • VDO 323-095, 325-002
Sensor Ground
Pressure Sensors
3 Wire Active Sensors
((picture of active sensor))
Sensor Breakout Board
We've created an optional sensor breakout / distribution board that will make it easier to use sensors that require pullup resistors as well as making available multiple ground and 5V Vref connections. The built-in pullup resistors are easily disabled by breaking a designated trace on the board. This board is compact; enough to be bundled inline with your wiring harness. SensorX board.png
SensorX
