RaceCapturePro Sensors
Revision as of 03:33, 30 December 2013 by Brentp (talk | contribs) (→Pressure Sensors: updated fluid sensors)
GM Style fluid sensors
Mfg Pic Pigtail Part Numbers Mechanical Notes
GM
  • Pigtail Pico 5615pt
3/8" NPT threaded brass body and a 2 pin terminal. Can be used for air inlet temperature for normally aspirated engines
GM
  • Pigtail Pico 5616pt
Analog channel configuration
0.37 212.00
0.51 178.00
1.99 104.0
2.47 72.0
4.24 23.0
AEM Fluid Sensors
Part # Pic Mechanical Notes
AEM-30-2012
  • 1/8" NPT
0.40 302.00
0.87 239.00
1.88 176.0
3.2 122.0
4.72 32.0
Infrared Temperature
Interface modules for these sensors are in research and development
Image Mfg / Part Description Notes
Mylexis MLX90620 16x4 matrix temperature sensor with I2C digital output. The matrix temperature sensor with a 60 degree field of view makes it ideal for a one-sensor tire temperature solution
Thermocouple Sensors
Pressure Sensors
Oil, fuel Pressure
Mfg Image Mechanical Description Notes
AEM
  • 1/8" NPT
  • 3 pin GM connector
  • Technical Information
Default kit from AEM includes pigtail
Various
  • 1/8" NPT port
Boost / Vacuum
GM 3.3 bar MAP sensor
  • Sensor: 9373269
  • Pigtail: 88987997
Tire Pressure
Pulse Sensors
Wheel Speed
Distance Sensors
Suspension Travel
Angle Sensors
Steering Angle
Throttle Position
Brake Position/Pressure
Linear Sensors
Temperature Sensor
Pullup resistor
  • VDO 323-095, 325-002
Sensor Ground
Pressure Sensors
3 Wire Active Sensors
((picture of active sensor))
Sensor Breakout Board
SensorX
