RaceCapturePro Sensors
GM Style fluid sensors
Mfg | Pic | Pigtail | Part Numbers | Mechanical | Notes | Analog Channel Configuration | ||||||||||||
GM |
GM |
AEM Fluid Sensors
Part # | Pic | Mechanical | Notes | Analog Channel Configuration | ||||||||||||
AEM-30-2012 |
Infrared Temperature
Interface modules for these sensors are in research and development
Image | Mfg / Part | Description | Notes |
Mylexis MLX90620 | 16x4 matrix temperature sensor with I2C digital output. The matrix temperature sensor with a 60 degree field of view makes it ideal for a one-sensor tire temperature solution |
Thermocouple Sensors
Analog Devices AD597 Type K Thermocouple amplifier | Low cost, easy to use thermocouple amplifier with 10mv/C temperature output directly from a K-Type thermocouple. Ideal for creating a simple thermocouple to 0-5v sensor. |
Maxim MAX31851 Thermocouple amplifier | Versatile thermocouple amplifier with 1-wire (I2C) digital interface. Ideal for monitoring multiple sensors |
Pressure Sensors
Oil, fuel Pressure
Mfg | Image | Mechanical | Description | Notes |
AEM |
Default kit from AEM includes pigtail | |
Various |
Boost / Vacuum
Tire Pressure
Mfg | Description | Pic | Pigtail | Part Numbers | Mechanical | Analog Configuration | Notes |
VDO | REDI-Sensor™ Multi-Application TPMS Sensors | self powered wireless | OEM style | custom | Wireless tire pressure monitoring system link | ||
ASL | Ford type throttle position sensor | turnkey unit | custom self powered wireless | Wireless tire pressure monitoring system includes wireless receiver and gauge link |
Pulse Sensors
Wheel Speed
Distance Sensors
Suspension Travel
Vishay Semiconductors | Specialized Optical Switch | 3-pin connector | Mouser Part #:782-TCND5000 Manufacturer Part #:TCND5000 | Optical Switches, Specialized Reflective Sensor w/PIN Photodiode Out | <link> | Optical distance sensor to be used for pedal travel as well, providing there is a target to sense Link |
Angle Sensors
Steering Angle
Throttle Position
ASL | Ford type throttle position sensor | see pigtail below | Standard Motors SMP TH45 equivalent | custom | Existing style Throttle position sensor available from AutoSport Labs link | ||
ASL | Ford type throttle position sensor | 3-pin connector | fits SMP TH45 above | custom | Existing style Throttle position sensor available from AutoSport Labs link |
Brake Position/Pressure
ATE | Brake Fluid Pressure sensor | solder on tabs (2 wire) | If your SKU number is 34331150922 than you'll want to reference OE Number 34331150922, 34-33-1-150-922, 80506001237. | <link to Race Capture analog channel configuration> | threads into T fitting on brake line. Use professional brake fitting tools! link | ||
DIY | Freescale MPX4250AP 2.5 bar MAP sensor | on part | ATV type sensor | threads into T fitting on brake line. Use professional brake fitting tools! | avail at 150psi, or 2000psi, needs 12v supply link |
Linear Sensors
Temperature Sensor
Pullup resistor
- GM-style TX3 / SU109 Coolant
- GM-style AX1 / SU107 Air Inlet Temp
- AEM 30-2012 1/8" NPT fluid temperature sensor
- VDO 323-095, 325-002
Sensor Ground
Pressure Sensors
3 Wire Active Sensors
((picture of active sensor))
Sensor Breakout Board
