RaceCapturePro Sensors
GM Style fluid sensors
Pico 5615pt |
Pico 5616pt |
AEM Fluid Sensors
| Mfg / Part # | Image | Pigtail | Mechanical | Description | Analog Channel Configuration | ||||||||||||
| AEM-30-2012 |
Infrared Temperature
Interface modules for these sensors are in research and development
| Mfg / Part | Image | Pigtail | Description | Notes | Analog Configuration |
| Mylexis MLX90620 |
Thermocouple Sensors
| Mfg / Part | Image | Pigtail | Description | Analog Configuration |
Pressure Sensors
Oil, fuel Pressure
| Mfg / Part # | Image | Mechanical | Description | Analog Configuration | ||||||||||||
| AEM 30-2131-150 |
| Various |
Boost / Vacuum
Tire Pressure
| Mfg | Description | Pic | Pigtail | Part Numbers | Mechanical | Analog Configuration | Notes |
| VDO | REDI-Sensor™ Multi-Application TPMS Sensors | self powered wireless | OEM style | custom | Wireless tire pressure monitoring system link | ||
| ASL | Ford type throttle position sensor | turnkey unit | custom self powered wireless | Wireless tire pressure monitoring system includes wireless receiver and gauge link |
Pulse Sensors
Wheel Speed
Distance Sensors
Suspension Travel
| Vishay Semiconductors | Specialized Optical Switch | 3-pin connector | Mouser Part #:782-TCND5000 Manufacturer Part #:TCND5000 | Optical Switches, Specialized Reflective Sensor w/PIN Photodiode Out | <link> | Optical distance sensor to be used for pedal travel as well, providing there is a target to sense Link |
Angle Sensors
Steering Angle
| DIY | Sharp GP2D12 optical distance sensor | 3-pin connector | GP2D12 | custom | <link> | Optical distance sensor measures from 10 to 80 cm and outputs a voltage corresponding to that distance. To measure suspension travel, install a unit at each corner of car, targeting the road surface. May also be used for pedal travel as well, providing there is a target to sense. Create a target latched to the steering rod and use the travel out and back of the steering rack rod to denote the travel left and right for steering. This measures true steering(and ignores the speed sensitivity of steering systems, showing actual tire angle result, not steering wheel rotation). It also provides a quick way to verify alignment issues as location vs. gps/accelerometer travel in the "Straight ahead" direction will be at varying angles when alignment issues are present. |
Throttle Position
| ASL | Ford type throttle position sensor | see pigtail below | Standard Motors SMP TH45 equivalent | custom | Existing style Throttle position sensor available from AutoSport Labs link | ||
| ASL | Ford type throttle position sensor | 3-pin connector | fits SMP TH45 above | custom | Existing style Throttle position sensor available from AutoSport Labs link |
Brake Position/Pressure
| ATE | Brake Fluid Pressure sensor | solder on tabs (2 wire) | If your SKU number is 34331150922 than you'll want to reference OE Number 34331150922, 34-33-1-150-922, 80506001237. | <link to Race Capture analog channel configuration> | threads into T fitting on brake line. Use professional brake fitting tools! link | ||
| DIY | Freescale MPX4250AP 2.5 bar MAP sensor | on part | ATV type sensor | threads into T fitting on brake line. Use professional brake fitting tools! | avail at 150psi, or 2000psi, needs 12v supply link |
Linear Sensors
Temperature Sensor
Pullup resistor
- GM-style TX3 / SU109 Coolant
- GM-style AX1 / SU107 Air Inlet Temp
- AEM 30-2012 1/8" NPT fluid temperature sensor
- VDO 323-095, 325-002
Sensor Ground
Pressure Sensors
3 Wire Active Sensors
((picture of active sensor))
Sensor Breakout Board
