RaceCapturePro Sensors
Revision as of 21:50, 4 January 2014 by Brentp (talk | contribs) (→Sensors: corrected pigtail)
GM-Style
  • Wells SU109
  • SMP TX3
Pico 5615pt
0.37 212.00
0.51 178.00
1.99 104.0
2.47 72.0
4.24 23.0
  • Wells SU107
  • SMP AX1
Pico 5616pt
AEM
AEM-30-2012
  • 1/8" NPT
0.40 302.00
0.87 239.00
1.88 176.0
3.2 122.0
4.72 32.0
Infrared Sensors
Mfg / Part # Image Notes
Mylexis MLX90620
  • Interface module queued for development
  • Technical Information
Thermocouple Sensors
Pressure Sensors
Fluid Pressure
Volts Scaled Value (PSI)
0.5 0.0
4.5 150.0
4.5 150.0
4.5 150.0
4.5 150.0
  • Sensor: 12223861 (GM)
  • vacuum port
3 bar MAP sensor
Volts Manifold Pressure (KPa)
0 3.6
1.25 80.0
2.5 159
3.75 237
5.0 315.0
Freescale MXP4250AP 2.5 bar MAP sensor
Tire Pressure
Schrader
  • OEM TMPS System
Pulse/Speed/RPM Sensors
Autosport Labs CoilX <image> The CoilX sensor module is designed to safely interface the noisy, high voltage RPM signal at the ignition coil pack primary into a clean signal that RaceCapture/Pro can process.
Wheel Speed / Gear speed
Cherry GS102301 File:Cherry GS102301 gear speed sensor.jpg
  • Operation up to 140c
  • Datasheet
Cherry GS100701
  • Low profile, aluminum body, flying leads
  • Operation up to 125c
  • Datasheet
Distance Sensors
Suspension Travel
Angle Sensors
Steering Angle
Throttle Position
Brake Position/Pressure
Linear Sensors
Temperature Sensor
Pullup resistor
  • VDO 323-095, 325-002
Sensor Ground
Pressure Sensors
3 Wire Active Sensors
((picture of active sensor))
Sensor Breakout Board
SensorX
