RaceCapturePro Sensors
Revision as of 03:13, 6 January 2014 by Brentp (talk | contribs) (added wiring link for string pot)
GM-Style
  • Wells SU109
  • SMP TX3
Pico 5615pt
0.37 212.00
0.51 178.00
1.99 104.0
2.47 72.0
4.24 23.0
  • Wells SU107
  • SMP AX1
Pico 5616pt
AEM
  • 1/8" NPT
0.40 302.00
0.87 239.00
1.88 176.0
3.2 122.0
4.72 32.0
Infrared Sensors
Mfg / Part # Image Notes
  • Interface module queued for development
  • Technical Information
Thermocouple Sensors
Analog Devices AD597 Type K Thermocouple amplifier Soic-8.jpg Low cost, easy to use thermocouple amplifier with 10mv/C temperature output directly from a K-Type thermocouple. Ideal for creating a simple thermocouple to 0-5v sensor.
Maxim MAX31851 Thermocouple amplifier Soic-8.jpg Versatile thermocouple amplifier with 1-wire (I2C) digital interface. Ideal for monitoring multiple sensors
Pressure Sensors
Fluid Pressure
AEM 30-2131-150 AEM-30-2131-150.jpg 3 pin GM connector 1/8" NPT
Volts Scaled Value (PSI)
0.5 0.0
4.5 150.0
4.5 150.0
4.5 150.0
4.5 150.0
Various 10 bar 150 psi ss pressure sensor.jpg 3 pin GM connector 1/8" NPT port
  • Sensor: 12223861 (GM)
  • vacuum port
3 bar MAP sensor
Volts Manifold Pressure (KPa)
0 3.6
1.25 80.0
2.5 159
3.75 237
5.0 315.0
Freescale MXP4250AP MPX4250ap.png 2.5 bar MAP sensor
Tire Pressure
Schrader
  • OEM TMPS System
Pulse/Speed/RPM Sensors
Autosport Labs CoilX <image> The CoilX sensor module is designed to safely interface the noisy, high voltage RPM signal at the ignition coil pack primary into a clean signal that RaceCapture/Pro can process.
Wheel Speed / Gear speed
Mfg / Part # Image Pigtail Mechanical Notes Pulse Channel Configuration
Cherry GS102301 File:Cherry GS102301 gear speed sensor.jpg
  • Operation up to 140c
  • Datasheet
  • Low profile, aluminum body, flying leads
  • Operation up to 125c
  • Datasheet
Distance Sensors
Ride Height
  • Datasheet
Steps to calibrate:
  7. Create Calibration Table:
  • Place the droop voltage / distance into the 1st column of the calibration table. Make the distance negative
  • Place the 'at rest' voltage / zero distance into the 2nd column of the calibration table.
  • BMW 37140141444
  • Pigtail: 61138383300
  • 5v power supply
  • Approximately 0-5v output
Various Mfg / String Potentiometer String Potentiometer.jpg
Angle / Rotation Sensors
Throttle Position (TPS)
Ford / SMP TH45 TPS-45.jpg 5752pt.jpg Screw mounted, keyed input for throttle shaft
To calibrate, note the voltage at 0% throttle and 100% throttle and create a 2 point analog scaling map.
Temperature Sensor
Pullup resistor
Sensor Ground
Active Sensors
  • Throttle Position Sensors
  • Linear sensors
  • String Potentiometers
Sensor Breakout Board
We've created an optional sensor breakout / distribution board that will make it easier to use sensors that require pullup resistors as well as making available multiple ground and 5V Vref connections. The built-in pullup resistors are easily disabled by breaking a designated trace on the board. This board is compact; enough to be bundled inline with your wiring harness. SensorX board.png
SensorX
