RaceCapturePro Sensors
Revision as of 06:42, 8 January 2014 by Brentp (talk | contribs) (→Sensors: added buy links for tps)
GM-Style
  • Wells SU109
  • SMP TX3
  • Pigtail: Pico 5615pt
0.37 212.00
0.51 178.00
1.99 104.0
2.47 72.0
4.24 23.0
  • Wells SU107
  • SMP AX1
  • Pigtail: Pico 5616pt
AEM
AEM-30-2012
  • 1/8" NPT
0.40 302.00
0.87 239.00
1.88 176.0
3.2 122.0
4.72 32.0
Infrared Sensors
Mfg / Part # Image Notes
Mylexis MLX90620
  • Interface module queued for development
  • Technical Information
Thermocouple Sensors
Pressure Sensors
Fluid Pressure
Volts Scaled Value (PSI)
0.5 0.0
4.5 150.0
4.5 150.0
4.5 150.0
4.5 150.0
  • Sensor: 12223861 (GM)
  • vacuum port
3 bar MAP sensor
Volts Manifold Pressure (KPa)
0 3.6
1.25 80.0
2.5 159
3.75 237
5.0 315.0
Freescale MXP4250AP
2.5 bar MAP sensor
Tire Pressure
Schrader
  • OEM TMPS System
Pulse/Speed/RPM Sensors
Autosport Labs CoilX <image> The CoilX sensor module is designed to safely interface the noisy, high voltage RPM signal at the ignition coil pack primary into a clean signal that RaceCapture/Pro can process.
Wheel Speed / Gear speed
Mfg / Part # Image Pigtail Mechanical Notes Pulse Channel Configuration
Cherry GS102301
File:Cherry GS102301 gear speed sensor.jpg
  • Operation up to 140c
  • Datasheet
Cherry GS100701
  • Low profile, aluminum body, flying leads
  • Operation up to 125c
  • Datasheet
Distance Sensors
Ride Height
Sharp GP2D12
  • Datasheet
Steps to calibrate:
  7. Create Calibration Table:
  • Place the droop voltage / distance into the 1st column of the calibration table. Make the distance negative
  • Place the 'at rest' voltage / zero distance into the 2nd column of the calibration table.
  • BMW 37140141444
  • Pigtail: 61138383300
  • 5v power supply
  • Approximately 0-5v output
Texense RHS
KA Sensors RHL3
Angle / Rotation Sensors
Throttle Position (TPS)
Ford / SMP TH45
Screw mounted, keyed input for throttle shaft
To calibrate, note the voltage at 0% throttle and 100% throttle and create a 2 point analog scaling map.
Temperature Sensor
Pullup resistor
Sensor Ground
Active Sensors
  • Throttle Position Sensors
  • Linear sensors
  • String Potentiometers
Sensor Breakout Board
SensorX
