CoilX
The CoilX RPM input module safely interfaces the signal from an ingition coil primary circuit into a clean square wave that can be safely handled by the RaceCapture/Pro Timer / RPM input.
The module features an optically isolated circuit with additional filtering, to help prevent false triggers.
The 1" x 0.5" compact board is designed to be assembled with heat shrink and bundled in-line with your wiring harness.
