RaceCapturePro installation guide
Power Connection
Analog Inputs 1-7
Active Sensors/Signals
Resistive sensor
Analog/Frequency Outputs 1 - 4
Frequency/Pulse Input 1 - 3
TACH SIGNAL NOTES
CoilX Sensor Module
Expansion Port
The RJ45 connector to the right of the terminal block is used for the CAN/OBDII bus expansion module or other custom hardware expansion devices.
SD Card Slot
USB Port
LED Indicators
- Power LED
- LED1
- LED2
- LED3
Pushbutton
Communication Ports
- Port 1
- Port 2
Used for GPS module
Shock isolation mounting
Internal Switches / Jumpers
4 position DIP switch (SW1)
GPIO configuration jumpers
Reset Pushbutton
Test Pushbutton
