Revision as of 18:31, 17 March 2007 by Brentp (talk | contribs) (continued edits)
EDIS installation
Wiring notes and guidelines
  • Use shielded cable for the VR Sensor. Be sure to ground the shield as well. A 2 conductor cable with a foil shield works well.
  • Note the VR sensor is polarized- you will not get spark from the EDIS module if it is wired backwards. If you don't see spark, reverse the connection on the VR sensor.
    • Ground both the EDIS and MJLJ at the same point on the chassis.
Installing the MJLJ
MJLJ wiring notes and guidlines
  • Use shielded cable for the PIP/SAW signal between the MJLJ and EDSI module. Be sure to ground the shield as well. A 2-conductor cable with a foil sheild works well.
OEM tach adapter
Many tachometers can accept the 12V signal emitted from the MJLJ module. however, some OEM tachs detect the RPM signal by sensing the high voltage flyback pulse from the ignition coil. In distributor based setups, there is only one ignition coil to detect this pulse from. With a wasted spark system like the Ford EDIS, you will have multiple coils providing this signal. Consequently you may need a way to detect this pulse across multiple coil-packs.
OEM tach adapter circuit
