Revision as of 23:31, 17 March 2007 by Brentp (talk | contribs) (fixed typos)
EDIS installation
Wiring notes and guidelines
  • Use shielded cable for the VR Sensor. Be sure to ground the shield as well. A 2 conductor cable with a foil shield works well.
Installing the MJLJ
Interfacing to Tachometers
User defined outputs
The User defined outputs provided by the MJLJ can be set to trigger on either RPM or Load thresholds. The configuration of these outputs is provided by the PC configuration software, covered in a later section.
Should you exceed the current capacity of one or more of the user defined outputs and damage the ULN2003 chip, replace the chip with a new unit- it is socketed for this specific reason.
For MJLJ firmware version 3.1.0 and later, the Option input is used to enable on-the-fly switching between Ignition Configurations, controllable via a dash mounted switch.
Rev Limit control
