Revision as of 01:28, 18 March 2007 by Brentp (talk | contribs) (→User defined outputs: a bit more detail)
EDIS installation
Wiring notes and guidelines
  • Use shielded cable for the VR Sensor. Be sure to ground the shield as well. A 2 conductor cable with a foil shield works well.
Installing the MJLJ
Interfacing to Tachometers
The four User defined outputs provided by the MJLJ can be set to trigger on either RPM or Load thresholds. The separate 'shift light' output triggers only on RPM, but otherwise behaves identically to the user outputs.
Rev Limit control
