Revision as of 05:49, 18 March 2007 by Brentp (talk | contribs)
EDIS installation
VR Sensor and bracket
Machined crank pulley with timing adapted
Closeup view of adapted timing wheel
Machined pulley with timing wheel adapted
Modified crank pulley mounted with VR Sensor
Wiring notes and guidelines
  • Use shielded cable for the VR Sensor. Be sure to ground the shield as well. A 2 conductor cable with a foil shield works well.
