Parts you will need
- EDIS module matching your engine type: EDIS-8 for 8 cylinder, EDIS-6 for 6 cylinder, EDIS-4 for 4 cylinder)
EDIS installation
| Type | Degrees BTDC |
| EDIS-4 | 90 |
| EDIS-6 | 60 |
| EDIS-8 | 50 |
With the Engine at TDC for cylinder #1, the sensor should be positioned 'N' degrees before the missing tooth. Make sure you take into account the rotation of the engine: clockwise or counter-clockwise, when determining your sensor mounting.
Wiring notes and guidelines
Installing the MJLJ
Interfacing to Tachometers
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
