V3.2.x / 2.8.x Backing up your current configuration
Revision as of 00:57, 22 April 2007 by Brentp (talk | contribs) (V3.1.x / 2.7.x Backing up your current configuration moved to V3.2.x / 2.8.x Backing up your current configuration: bump for released version)
The upgrade process for your MJLJ will erase your ignition configuration and restore the 'factory default' values.
Before continuing, you should save your existing ignition configuration. You can do so by following these steps:
- Power up your MJLJ unit
- Start the MJLJ configuration software with the serial cable connected to your controller
- If needed, read the controller's ignition configuration.
- Click File / Save and save your configuration to a file.
This file will be used later to restore your configuration after you've loaded the new MJLJ firmware.
