Revision as of 18:53, 19 August 2007 by Brentp (talk | contribs) (Reverted edits by LaurieBorseth (Talk); changed back to last version by Brentp)
Parts you will need
    • EDIS-8 for 8 cylinder
    • EDIS-6 for 6 cylinder
    • EDIS-4 for 4 cylinder
EDIS installation
Sensor Position
Type Degrees BTDC
EDIS-4 90
EDIS-6 60
EDIS-8 50
Wiring notes and guidelines
  • Use shielded cable for the VR Sensor. Be sure to ground the shield as well. A 2 conductor cable with a foil shield works well.
Installing the MJLJ
MAP Sensor operation
TPS Sensor operation
Interfacing to Tachometers
Using EDIS PIP signal
An alternate approach that appears to work with older 'Smiths' type tachometers is to share the PIP signal that is emitted from the EDIS module. The PIP output is a 12V square wave with a larger duty cycle than the TACH_OUT provided by the MJLJ. Simply wire the EDIS PIP output to both the MJLJ PIP input as well as the tachometer sense wire.
Rev Limit control
MJLJ Operation
Verifying MJLJ operation
