RaceCapturePro2 OBD2
Enabling OBD-II
Supported OBD-II interfaces
Currently RaceCapture/Pro supports the CAN bus protocol for OBD-II for 2008 and newer ECUs.
System Configuration
  • Pre-requisites: Ensure you have firmware version 2.7.3 or later.
  • Start the RaceCapture app and read the current configuration from RaceCapture/Pro
  • Navigate to the Configuration / OBD-II view
Enable CAN bus
  • Enable the CAN bus and select the baud rate for your interface.
  • Protip: Most ECUs operatate at 500K or 250K baud. Try 500K first, then 250K. If neither work, consult the vehicle manufacturer
Enable OBD-II Channels
  • Enable OBD2 by enabling the switch at the top
  • press the "+" button at the bottom to add a new OBD-II channel.
    • Specify the channel and logged sample rate.
    • Protip: The OBD-II protocol requests data sequentially, one query per enabled channel. The logged sample rate may be slower than the actual rate OBD-II data is retrieved from the ECU, especially if many channels are enabled.
Write the configuration
  • Write the configuration back to RaceCapture/Pro
Connect OBD-II cable
  • Connect OBD-II cable and plug the RJ-45 end into the plug next to the green terminal block.
  • Protip: You can power RaceCapture/Pro (MK2) from the OBD-II connection, for a plug and play installation
Observe OBD-II data
With the engine running and app connected in dashboard mode, navigate to the dashboard's raw channel view - you can observe the OBD-II data streaming along with the other sensor values. This OBD-II data will be included in the data logged to SD card and telemetry stream.
