AIM CAN
Revision as of 21:46, 8 January 2015 by Jstoezel (talk | contribs) (Created page with "'''AIM Mychron 3 Dash''' The following information is a sum up of reverse engineering findings documented here: [http://sites.google.com/site/mychron3/home/can-bus-protocol]. Ex...")
AIM Mychron 3 Dash
The following information is a sum up of reverse engineering findings documented here: [1]. Example of LUA implementation of the the different packets documented on the Mychron 3 Hack page are provided below:
TODO
TODO
Packet 404h: Control for fields displayed on bottom left of display
TODO
TODO
TODO
Packet 408h: Timing
TODO
