AIM CAN
This section documents how to control an AIM Mychron3 Dash display, using an RCP unit via LUA scripting. The following information is a sum up of reverse engineering findings documented here: [1]. Examples of LUA implementation of the the different packets documented on the Mychron 3 Hack page are provided below.
   local rpm = getTimerRpm(0)
   local speedmph = getGpsSpeed()
   -- Assume the gear is calculated and stored in a virtual channel.
   -- Refer to LUA scripting example to calculate the gear based on speed and RPM
   local gear = getChannel(gearId)
   local msg = {rpm % 256, rpm / 256, (speedmph % 16) % 256, (speedmph / 16) / 256, 0, 0, gear, 0}
   txCAN(0, 1025, 0, msg)
   -- Assume different temperature values are stored in virtual channels
   local temp1 = getChannel(temp1Id)
   local temp2 = getChannel(temp2Id)
   local temp3 = getChannel(temp3Id)
   local temp4 = getChannel(temp4Id)
   local msg = {temp1 % 256, temp1 / 256, temp2 % 256, temp2 / 256, temp3 % 256, temp3 / 256, temp4 % 4, temp4 / 256}
   txCAN(0, 1026, 0, msg)
Byte[6]:4-0: Controls the shift LEDs. The LEDs are bitmaped, meaning the far most LEDs on each side of the display turn on if bit 1 is set, bit 2 controls the second farthest LEDs from the centre. A value of 0x1F turns on all the LEDs and make them blink.
   local msg = {0, 0, 0, 0, 0, 0, temp4 % 4, 0}
   txCAN(0, 1029, 0, msg)
   -- Set the RPM range
   -- Value  	 RPM Range
   -- 0	 25,000 - 0
   -- 1	 22,000 - 0
   -- 2	 20,000 - 0
   -- 3	 16,000 - 0
   -- 4	 12,000 - 0
   -- 5	 10,000 - 0
   -- 6	 8,000 - 0
   -- 7	 6,000 - 0
   -- 8	 4,000 - 0
   local rpmRange = 6 -- Up to 8000 RPM
   local rpm =
   local msg = {0, rpmRange * 16, 0, 0, 0, 0, 0, 0}
   txCAN(0, 1030, 0, msg)
Packet 408h: Timing
TODO
