AIM CAN
This section documents how to control an AIM Mychron3 Dash display, using an RCP unit via LUA scripting. The following information is a sum up of reverse engineering findings documented here: [1]. Examples of LUA implementation of the the different packets documented on the Mychron 3 Hack page are provided below.
local rpm = getTimerRpm(0)
local speedmph = getGpsSpeed()
-- Assume the gear is calculated and stored in a virtual channel.
-- Refer to LUA scripting example to calculate the gear based on speed and RPM
local gear = getChannel(gearId)
local msg = {rpm % 256, rpm / 256, (speedmph % 16) % 256, (speedmph / 16) / 256, 0, 0, gear, 0}
txCAN(0, 1025, 0, msg)
-- Assume different temperature values are stored in virtual channels
local temp1 = getChannel(temp1Id)
local temp2 = getChannel(temp2Id)
local temp3 = getChannel(temp3Id)
local temp4 = getChannel(temp4Id)
local msg = {temp1 % 256, temp1 / 256, temp2 % 256, temp2 / 256, temp3 % 256, temp3 / 256, temp4 % 4, temp4 / 256}
txCAN(0, 1026, 0, msg)
local shiftLeds = 0
if rpm > 5000 then shiftLeds = shiftLeds + 1 end
if rpm > 6000 then shiftLeds = shiftLeds + 2 end
if rpm > 7000 then shiftLeds = shiftLeds + 4 end
if rpm > 7500 then shiftLeds = shiftLeds + 8 end
if rpm > 7700 then shiftLeds = shiftLeds + 16 end
local msg = {0, 0, 0, 0, 0, 0, shiftLeds, 0}
txCAN(0, 1029, 0, msg)
-- Set the RPM range
-- Value RPM Range
-- 0 25,000 - 0
-- 1 22,000 - 0
-- 2 20,000 - 0
-- 3 16,000 - 0
-- 4 12,000 - 0
-- 5 10,000 - 0
-- 6 8,000 - 0
-- 7 6,000 - 0
-- 8 4,000 - 0
local rpmRange = 6 -- Up to 8000 RPM
local msg = {0, rpmRange * 16, 0, 0, 0, 0, 0, 0}
txCAN(0, 1030, 0, msg)
Packet 408h: Timing
TODO
