Revision as of 18:07, 25 January 2015 by Brentp (talk | contribs) (→Troubleshooting: updated to refer)
Telemetry Quickstart
Prerequisites
Get a device Id
Integrated Telemetry
Purchasing a SIM Card
We recommend a full-sized SIM card with a compatible data plan from a supported carrier.
Which SIM card to get?
  • T-Mobile
Recommended: Purchase a "Pay By the Day" SIM card from your local T-Mobile dealer. We recommend picking a plan with the 2G/3G unlimited data, which is currently $3 USD/day. The plan is only charged when data is actually used during a 24 hour period. Visit T-Mobile for more details on prepaid plans.
T-Mobile Coverage map tool
  • AT&T
AT&T SIM cards supported. We recommend a pay-as-you go plan that includes data
AT&T Coverage Map tool
  • Global/Other carriers
The RaceCapture/Pro uses a world-wide compatible GSM cellular module. Check with your carrier for support.
Installing the SIM card
  • Use a pen or a small screwdriver and press the yellow eject button next to the SIM card slot - the card slot will pop out slightly from the front panel. Manually withdraw it from the front panel.
  • Insert the SIM card into the holder, noting the angled notch. Re-insert and press until the front edge is flush or just below the surface of the enclosure face.
  • IMPORTANT NOTE the SIM card tray inserts into the unit with the word "SIM" oriented upside down, with the SIM card facing down. The card carrier should slide in smoothly, and require a bit of force to lock in to place. Take care to not force the card in at an angle.
Attach Cellular Antenna
Connect the included antenna to the antenna port to the left of the SIM card slot. Tighten until snug.
  • Do not over-tighten antenna connection
  • Connect RaceCapture/Pro to your computer with USB and run the RaceCapture software.
    • Note: If this is the first time connecting, be sure you've gone through the Quick Start Guide
  • After the software detects and connects to RaceCapture/Pro, navigate to the configuration screen
Enable Telemetry and Device Id
  • Select the Telemetry option on the left side
  • Enter the Device Id you obtained from your race-capture.com account in the Device Id field.
    • if your carrier is not listed, specify the APN settings provided by your wireless company.
Write and Save Configuration
  • Write your configuration back to the unit using the buttons in the lower left of the screen.
  • Recommended: save your configuration to a file
Testing Telemetry
  • Ensure the SIM card is installed in the RaceCapture/Pro unit per the earlier steps.
Powering up
Watching for telemetry
  • When searching for the network, the top green telemetry LED will flash in a slow pattern.
  • When connected and transmitting, the top green LED will flash rapidly and steadily.
  • You can view the live data by clicking on the event
    • You can also edit and rename this event
Setting up future events
  • No 12v power: The internal telemetry module requires external 12v (via green terminal block or OBD-II cable)
    • Computer USB does not provide enough power to operate the cellular module.
  • Incorrect cellular plan: Check with the carrier and confirm the plan is enabled with data.
  • Incorrect APN settings: While T-Mobile makes it easy by always using the same APN, AT&T is known to require various APN settings based on the type of data plan.
    • For AT&T, try the alternate AT&T settings (AT&T Alt #1 and Alt #2) if you cannot get a connection.
    • For other carriers, contact their technical support to get a custom APN setting for their network.
  • Poor signal quality: Ensure coverage area.
  • Loose antenna: Ensure the antenna is snugly cinched to the connector.
  • Missing / Incorrect Device Id: Ensure RaceCapture/Pro is configured with a Device ID provided by race-capture.com
Debugging Cellular activity
  • Navigate to Configuration/Scripting and enable debug level logging.
    • Check the 'poll logfile' option
    • Select 'Debug' from the dropdown list.
  • You will see the low-level conversation between RaceCapture/Pro and the cellular module.
Bluetooth Telemetry
Install the RaceCapture App
Configure Bluetooth
  • Plug the Bluetooth module into the wireless connectivity port on RaceCapture/Pro and apply power (12v or USB)
  • Associate the Bluetooth module with your android device in the system settings.
    • Default password is 1234
  • In the RaceCapture App touch the Bluetooth icon and select the RaceCapturePro device you associated in the previous step.
  • The RaceCapture app will negotiate a connection to RaceCapture/Pro.
    • Once connected, the LED on the bluetooth module will remain steadily lit
    • Tip 1 - If the the app does not connect, close the RaceCapture app completely (dismiss from the background apps) and re-start.
    • Tip 2 - If you still cannot connect, enable / disable the bluetooth system in the device settings
Configure your Device Id
Verify Telemetry
  • Dim Green Not active
  • Red Connection Error
View Telemetry Stream
