Emtron
Revision as of 03:08, 5 February 2015 by Brentp (talk | contribs) (Created page with "=Emtron ECU= ==Configuration== This script integrates the Emtron ECU with RaceCapture/Pro telemetry. ==Baud Rate== Baud Rate is: ==Channels== ===TPS=== * CAN ID: 1251 * Bytes:...")
Emtron ECU
Configuration
Baud Rate
Baud Rate is:
Channels
TPS
  • CAN ID: 1251
  • Bytes: 5,6
  • Scaling: 0 = -100.0% ; 2000 = 100.0%
Lua Script
setTickRate(30) --30Hz
--set up virtual channels
tps_id = addChannel("TPS", 10, 1)
--handle TPS message data
function process_tps(data)
    local tps = data[5] * 256 + data[6]
    tps = (tps - 1000) / 10
    setChannel(tps_id, tps)
        id, e, data = rxCAN(0)
        if id == 1251 then process_tps(data) end
    until id == nil
