Emtron
Emtron ECU
Configuration
This script integrates the Emtron ECU with RaceCapture/Pro telemetry, using the factory standard CAN bus mapping
Baud Rate
Baud Rate is:
Channels
TPS
- CAN ID: 1251
- Bytes: 1,2
- Scaling: 0 = -100.0% ; 2000 = 100.0%
Lua Script
setTickRate(30) --30Hz --set up virtual channels tps_id = addChannel("TPS", 10, 1) --handle TPS message data function process_tps(data) local tps = data[1] * 256 + data[2] tps = (tps - 1000) / 10 setChannel(tps_id, tps) end function onTick() repeat --will drain CAN buffer on each tick id, e, data = rxCAN(0) if id == 1251 then process_tps(data) end until id == nil end
