Emtron
Revision as of 22:48, 12 February 2015 by Brentp (talk | contribs) (→Lua Script: fixed offset)
Emtron ECU
Configuration
This script integrates the Emtron ECU with RaceCapture/Pro telemetry, using the factory standard CAN bus mapping
Baud Rate
The default baud rate for Emtron is 1mbps.
  • You can configure this on the CAN bus configuration page in the RaceCapture App.
Channels
TPS
  • CAN ID: 1251
  • Bytes: 1,2 (little endian)
  • Scaling: 1000 = 0.0% ; 2000 = 100.0%
  • Precision: 0.1
Lua Script
setTickRate(30) --30Hz
--set up virtual channels
tps_id = addChannel("TPS", 10, 1)
--handle TPS message data
function process_tps(data)
    local tps = ((data[2] * 256 + data[1]) - 1000) * 0.1
    setChannel(tps_id, tps)
        id, e, data = rxCAN(0)
        if id == 1251 then process_tps(data) end
    until id == nil
