Cosworth CAN
Revision as of 05:23, 27 February 2015 by Brentp (talk | contribs) (initial channel for testing)
--Cosworth CAN bus integration
tickRate = 30
--the CAN baud rate
CAN_baud = 1000000
CAN_chan = 0
be_mode = 1
CAN_map = {
[256] = function(data) map_chan(tpsId, data, 7, 1, 1, 0) end
    processCAN(CAN_chan)
function processCAN(chan)
    repeat
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
    until id == nil
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
    offset = offset + 1
    local value = 0
    while len > 0 do
        offset = offset + 1
        len = len - 1
initCAN(CAN_chan, CAN_baud)
