TachAdapter
Revision as of 17:38, 13 March 2015 by Brentp (talk | contribs) (Installation)
Tachometer Adapter
This small board adapts a Tachometer to up to 4 individual coil packs, capable of handling 4, 6 or 8 cylinder wasted spark applications.
Available for purchase in our Online Store
Installation:
  • Connect Coil 1,2,3 and 4 to the drive signals to each coil packs as necessary.
    • We recommend 24 gauge wire, but wire gauge is not critical- so long as it fits the module.
  • Connect the tach output to the input of your tachometer.
  • Seal the module with shrink tubing or electrical tape- the board is small enough to integrate into your wire harness / bundle.
Example Wiring
Example wiring for a 4 cylinder wasted spark application: yellow wire connects to Tachometer input; red and black wire connect to the drive signals for the coil packs.
Schematics
