RaceCapturePro Sensors
GM-Style | |||||||||||||||||
AEM | |||||||||||||||||
| Mylexis MLX90620 |
3 bar MAP sensor |
| Freescale MXP4250AP | 2.5 bar MAP sensor
| Schrader |
RPM | |||||||||||||||||
| Autosport Labs CoilX |
The CoilX sensor module is designed to safely interface the noisy, high voltage RPM signal at the ignition coil pack primary into a clean signal that RaceCapture/Pro can process. | |||||||||||||||
| Mfg / Part # | Image | Notes | Pulse Channel Configuration | ||||||||||||||
| Hamlin 55505 |
| Cherry GS100701 |
| Sharp GP2D12 |
Steps to calibrate:
| Texense RHS |
| KA Sensors RHL3 |
| Various Mfg / String Potentiometer |
To calibrate, note the voltage at 0% throttle and then at 100% throttle. Use these two numbers to create a 2 point analog scaling map. | ||||||||||||||
Wiring Analog Sensors
- Input Impedance: 15K ohm
Temperature Sensor
Pullup resistor
Sensor Ground
Active Sensors
- Throttle Position Sensors
- Linear sensors
- String Potentiometers
Sensor Breakout Board
