How To Update Firmware
RaceCapture/Pro MK2
- How to video: Video: How to update firmware
Save your configuration
- Press the 'Configuration' button to navigate to the configuration section.
- On the left menu, select Firmware
- On the firmware screen, press the button "Update Firmware"
- Navigate to the firmware file ending in ".ihex"
- Select this file. The firmware will update and show a percentage progress indicator.
- If there is a problem detecting RaceCapture/Pro, unplug/replug and restart the app.
Alternative method
- While holding down the button on RaceCapture/Pro, power it up by plugging in to USB.
- You should observe a rapidly flashing red LED on the unit: it is in bootloader mode.
- Navigate to the configuration/firmware update screen, select the firmware file and update the firmware.
RaceCapture/Pro MK1
- Hold down the front panel button on RCP right at the beginning of the process, before running flashRCP.bat
- When asked 'is this your first time flashing' say 'No' so it will re-install the bootloader drivers
- Then proceed with the firmware flash update.
Alternatively:
Mac Users
For Mac users you will need to use a Windows VM to connect to RCP. Free virtual machine images are available here: http://dev.modern.ie/tools/vms/ You will need to add a network adapter to the VM. After that follow the Windows instructions.
