Haltech PS1000 - PS2000
Revision as of 01:47, 31 July 2015 by Brentp (talk | contribs) (→Haltech PS2000 and PS1000)
The following script will map the common Haltech CAN bus channels to RaceCapture/Pro:
--Designed for Haltech PS1000/PS2000 CAN Logging
--HALTECH CAN V2 Broadcast Protocol
--============================== Set Variables =================================
setTickRate(30)
initCAN(0, 1000000)
CAN_chan = 0 -- 0=first CAN channel, 1=second
--comment out channels if reqd
--note Haltech quotes IDs in HEX and must be converted to Decimal
--usage: map_chan(var, data, starting byte, byte length, Unit, Offset)
CAN_map = {
  [864] = function(data)
    map_chan(rpmId, data, 0, 2, 1, 0)
    map_chan(mapId, data, 2, 2, 0.1, -101.3)
    map_chan(tpsId, data, 4, 2, 0.1, 0)
    end,
  [865] = function(data)
    map_chan(fpsId, data, 0, 2, 0.1, 0)
    map_chan(opsId, data, 2, 2, 0.1, 0)
    end,
  [866] = function(data)
    map_chan(idcId, data, 0, 2, 0.1, 0)
    end,
  [872] = function(data)
    map_chan(afrId, data, 0, 2, 0.001, 0)
    end,
  [992] = function(data)
    map_chan(ctsId, data, 0, 2, 0.1, -273.1)
    map_chan(atsId, data, 2, 2, 0.1, -273.1)
    map_chan(ftsId, data, 4, 2, 0.1, -273.1)
    map_chan(otsId, data, 6, 2, 0.1, -273.1)
    end,
  [993] = function(data)
    map_chan(flxId, data, 4, 2, 0.1, 0) end
--=============================== Add Virtual Channels ==========================
--usage: addChannel("Name",samplerate{1,10,25,50,100,200},precision(2),min(0),max(1000),units)
rpmId = addChannel("RPM", 25, 0, 0, 10000, 'RPM')
mapId = addChannel("MAP", 10, 1, 0, 100, 'kPa')
tpsId = addChannel("TPS", 10, 1, 0, 100, '%')
fpsId = addChannel("FPS", 10, 1, 0, 100, 'kPa')
opsId = addChannel("OPS", 10, 1, 0, 100, 'kPa')
idcId = addChannel("IDC", 10, 0, 0, 100, '%')
afrId = addChannel("AFR", 10, 2, 0, 5, 'Lambda')
ctsId = addChannel("CTS", 10, 1, 0, 200, 'C')
atsId = addChannel("IAT", 10, 1, 0, 200, 'C')
ftsId = addChannel("FTS", 10, 1, 0, 200, 'C')
otsId = addChannel("OTS", 10, 1, 0, 200, 'C')
flxId = addChannel("FLX", 10, 0, 0, 100, '%')
--========================== Init ===================================
  processCAN()
--========================== CAN =============================
function processCAN() --finds an id that exists then passes it to
  repeat
    local id, e, data = rxCAN(0)
    if id ~= nil then  -- step through CAN data until you get a value
      local map = CAN_map[id]
      if map ~= nil then
        map(data) --this runs map_chan function with the CAN 'data'
  until id == nil
function map_chan(cid, data, offset, len, mult, add) --eg (rpmId, data, 0, 2, 1, 0)
  offset = offset + 1
  local value = 0
  while len > 0 do
    offset = offset + 1
    len = len - 1
