RaceCapturePro2 QuickStart
Prerequisites
Quick Start
Running the Application
  2. Click on 'Dashboard'
  4. Once the tracks have been selected, write the updated configuration using the button in the lower left.
Setting up Bluetooth
  1. Complete the Quick Start steps above, leaving RaceCapture/Pro connected to your computer
  2. Connect the Bluetooth module to the inner of the two RaceCapture/Pro ports on the same side the USB cable connects to
  3. Open the Race Capture app
  4. Click on the top left 'Menu' button
  5. Click on 'Configuration'
  6. Click on 'Wireless' in the list of options on the left
  7. Click the toggle to the right of 'Bluetooth'
  8. Click the 'Write Config' button on the bottom left (down array pointing to a RaceCapture/Pro)
Set up Android tablet/phone
Requirements
  • Android 4.4 and higher
  • Quad core 1.6 GHz processor
  • 2 GB RAM, 8 GB flash
  • 7" or 10" screen
Recommended Brands for tablets:
  • Samsung
  • Google Nexus
  • LG
  • Lenovo
Bluetooth pairing
    3. Default password is 1234
  2. Install the Race Capture app on your Android device from the Google Play Store
  3. Open the RaceCapture app, tap the screen until the RaceCapture logo show up at the top.
  4. Tap the Bluetooth icon at the top right
  5. Select RaceCapture/Pro
  6. After a few seconds you should see a 'Connected to RaceCapture/Pro' message and data will be transmitting to your tablet.
    1. The green light on the Bluetooth module should be solid and not flashing
Verify connectivity
  1. Swipe to the digital dash screen and you should see values changing. Pick up your RaceCapture/Pro and move it around, you should see even more sensors changing!
Basic Logging of Data
Use a 32GB card or smaller
The filename will end in .log
The logfile is in plain CSV data format.
