RaceCapturePro2 QuickStart
Revision as of 21:29, 9 October 2015 by Brentp (talk | contribs) (→Selecting your favorite race tracks)
Prerequisites
- Download and install the latest RaceCapture App
- Note for Windows 8 users - These drivers are unsigned. We are working on creating a signed driver set, but in the meantime you will need to disable the driver signing requirement for Windows 8. Instructions
Quick Start
- Attach GPS and Bluetooth module (if purchased) to RaceCapture/Pro
- Plug in the supplied USB cable to RaceCapture/Pro and your computer.
- When prompted for drivers, select them from the zip file you unzipped previously.
- If not prompted or Windows does not ask you to locate drivers, open Device Manager, find RaceCapture/Pro (usually under 'Other devices'), right click and select 'Update Driver' software. Then select the folder containing the unzipped drivers you downloaded previously.
- Confirm you really want to install the drivers
Running the Application
- Open the RaceCapture application.
- You should see 'Reading Configuration' at the top of the window once the app detects RaceCapture/Pro.
- Click on 'Dashboard'
- Click on the bottom right arrow three times, which will display the digital dash. You should see the Utc and Interval channels changing, which means data is being transmitted over USB.
- Protip: Pick up the RaceCapture/Pro unit, move it around and observe changes from the internal accelerometer and gyro sensors!
- You have now setup the RaceCapture app!
- After connecting the RaceCapture app and verifying connectivity, navigate to the configuration view.
- Select the Race Tracks from the menu on the left.
- Search and select the race tracks you will be typically attending.
- Once the tracks have been selected, write the updated configuration using the
button in the lower left.
Setting up Bluetooth
- Complete the Quick Start steps above, leaving RaceCapture/Pro connected to your computer
- Connect the Bluetooth module to the inner of the two RaceCapture/Pro ports on the same side the USB cable connects to
- Open the Race Capture app
- Click on the top left 'Menu' button
- Click on 'Configuration'
- Click on 'Wireless' in the list of options on the left
- Click the toggle to the right of 'Bluetooth'
- Click the 'Write Config' button on the bottom left (down array pointing to a RaceCapture/Pro)
Set up Android tablet/phone
Requirements
- Android 4.4 and higher
- Quad core 1.6 GHz processor
- 2 GB RAM, 8 GB flash
- 1024x600 resolution, IPS display
- 7" or 10" screen
Recommended Brands for tablets:
- Samsung
- Google Nexus
- LG
- Lenovo
Bluetooth pairing
- Go into the Android settings and pair your device with the RaceCapture/Pro Bluetooth module
- Ensure Bluetooth is turned on in the Android device settings.
- Ensure the RaceCapture/Pro Bluetooth module is powered on (green light is flashing)
- Default password is 1234
- Install the Race Capture app on your Android device from the Google Play Store
- Open the RaceCapture app. The RaceCapture app will search for the RaceCapturePro device
Verify connectivity
- Select the dashboard screen and switch to the raw channels view - you should see values updating in real-time.
Troubleshooting Bluetooth connection issues
- Ensure RaceCapture/Pro is powered up and the Bluetooth module is plugged in to the inner RJ11 port, located to the right of the front panel push-button
- Ensure Bluetooth is enabled in the wireless settings of the RaceCapture/Pro configuration
- Note, you will need to connect via USB to verify this setting
- Ensure Bluetooth is enabled under the Android Settings
- On some tablets with a marginal or unstable Bluetooth support, a disable/re-enable of Bluetooth may help
- Try un-pairing and re-pairing the RaceCapture/Pro Bluetooth device
- Try re-starting the Android device
Basic Logging of Data
- Insert a micro SD card into SD card slot on the front face of the unit.
- Use a 32GB card or smaller
- Press the button on the front of the panel. You will see the Logging LED flash
- When you are finished logging, press the button again. THe Logging LED will stop flashing.
- Remove the card. You will find your log file on the SD card.
- The filename will end in .log
- The logfile is in plain CSV data format.
Automatic logging control
