Link G4
The following script adapts the Link G4+ to RaceCapture/Pro
Notes: Uses the Generic Dash 2 profile.
Status: Needs verification
--This example configured for Link G4+ ECU --how frequently we poll for CAN messages tickRate = 30 --the CAN baud rate CAN_baud = 1000000 --CAN channel to listen on. 0=first CAN channel, 1=second CAN_chan = 0 --1 for Big Endian (MSB) mode; 0 for Little Endian mode (LSB) be_mode = 1 --add your virtual channels here --params: <channel name>,<sample rate>, <logging precision>, <min value>, <max value>, <units label> rpmId = addChannel("RPM", 10, 0, 0, 10000) tempId = addChannel("EngineTemp", 1, 0, -50, 205, "C") iatId = addChannel("IAT", 10, 0, -20, 205, "C") oilTempId = addChannel("OilTemp", 1, 0, -20, 205, "F") tpsId = addChannel("TPS", 10, 0, 0, 100, "%") ignAdvId = addChannel("IgnTiming", 10, 0, -100, 100, "Deg") wheelSpdId = addChannel("WheelSpeed", 10, 0, 0, 300, "kph") oilPressId = addChannel("OilPress", 10, 0, 0, 1000, "kPa") fuelPressId = addChannel("FuelPress", 10, 0, 0, 1000, "kPa") lambda1 = addChannel("Lambda1", 10, 3, 0, 3, "") lambda2 = addChannel("Lambda2", 10, 3, 0, 3, "") steerId = addChannel("Steering", 10, 0, -360, 360) baroId = addChannel("Baro", 1, 0, 0, 200, "kPa") gearId = addChannel("Gear", 5, 0, 0, 6, "") knockId = addChannel("Knock", 10, 0, 0, 1000, "") ---------------------------------------- --customize here for CAN channel mapping --format is: --[CAN Id] = function(data) map_chan(<chan_id>, data, <CAN offset>, <CAN length>, <multiplier>, -- <adder>, [filter]) ---------------------------------------- CAN_map = { [1200] = function(data) map_chan(rpmId, data, 0, 2, 1, 0) map_chan(tempId, data, 4, 1, 1, -50) map_chan(iatId, data, 5, 1, 1, -50) map_chan(oilTempId, data, 7, 1, 1, -50) end, [1201] = function(data) map_chan(tpsId, data, 0, 2, 0.1, 0) map_chan(ignAdvId, data, 2, 2, 0.1, -100) map_chan(wheelSpdId, data, 4, 1, 0.1, 0) map_chan(oilPressId, data, 5, 1, 1, 0) map_chan(fuelPressId, data, 6, 1, 1, 0) end, [1202] = function(data) map_chan(lambda1, data, 0, 2, 0.001, 0) map_chan(lambda2, data, 2, 2, 0.001, 0) map_chan(steerId, data, 4, 2, 0.1, -3000) map_chan(baroId, data, 6, 2, 0.1, 0) end, [1203] = function(data) map_chan(gearId, data, 0, 1, 1, 0) map_chan(knockId, data, 6, 2, 5, 0) end } function onTick() processCAN(CAN_chan) end --===========do not edit below=========== function processCAN(chan) repeat local id, e, data = rxCAN(chan) if id ~= nil then local map = CAN_map[id] if map ~= nil then map(data) end end until id == nil end --Map CAN channel, little endian format function map_chan_le(cid, data, offset, len, mult, add, filter) offset = offset + 1 local value = 0 local shift = 1 while len > 0 do value = value + (data[offset] * shift) shift = shift * 256 offset = offset + 1 len = len - 1 end local cv = value * mult + add if filter ~= nil then cv = filter(cv) end setChannel(cid, cv) end --Map CAN channel, big endian format function map_chan_be(cid, data, offset, len, mult, add, filter) offset = offset + 1 local value = 0 while len > 0 do value = (value * 256) + data[offset] offset = offset + 1 len = len - 1 end local cv = value * mult + add if filter ~= nil then cv = filter(cv) end setChannel(cid, cv) end map_chan = (be_mode == 1) and map_chan_be or map_chan_le initCAN(CAN_chan, CAN_baud) setTickRate(tickRate)
