RaceCapturePro Analysis
Revision as of 03:19, 25 November 2015 by Brentp (talk | contribs) (Created page with "==Upload your datalog for viewing online== If you have data logged to an SD card you can now upload the data for viewing online. Image:log-file-upload.jpg These are the...")
These are the same tools you get when streaming data live; perfect for analyzing data when you're out of cellular coverage.
Steps to upload:
  • Create an event on race-capture.com
  • Add a device to the event.
  • On this page, select the log file you wish to upload.
Once uploaded, your data will be processed and within a few minutes your data will appear. You can add more than one file by repeating the process.
From there you can share and analyze from anywhere in the world using just a web browser.
Requirements for uploading:
  • The analysis software requires laps to be present in the data, so you need to be at a race track where you have a track configuration selected, or, you've manually set a start/finish line.
