BMW E30 Guide
Revision as of 16:45, 21 March 2016 by Brentp (talk | contribs) (Created page with "=BMW E30 (1982 to 1993)= 500px ==RPM== Use the Black wire in the C101 plug feeding from the ECU to the instrument cluster. ===RaceCapture/Pro tim...")
RaceCapture/Pro timer configuration
  • Timer Mode: RPM
  • Timer Speed: Medium
  • Pulse Per Revolution: 3
Engine Temperature
In research
Fuel Level
In reserach
Oil Pressure
