RaceCapturePro installation guide
Revision as of 04:20, 5 April 2016 by Rdoherty (talk | contribs)
MK1 Installation Guide
This guide is for MK1, MK2 guide is here: https://www.autosportlabs.net/RaceCapturePro2_Hardware_Install
Power Connection
Analog Inputs 1-7
  • Input Impedance: 15K ohm
Active Sensors/Signals
Resistive sensor
Analog/Frequency Outputs 1 - 4
DIP switch setting
Jumper Configuration
Frequency/Pulse Input 1 - 3
TACH SIGNAL NOTES
CoilX CoilX Sensor Module
Expansion Port
The RJ45 connector to the right of the terminal block is used for the CAN/OBDII bus expansion module or other custom hardware expansion devices.
SD Card Slot
USB Port
LED Indicators
  • Power LED
  • LED1
  • LED2
  • LED3
Pushbutton
Communication Ports
  • Port 1
  • Port 2
Used for GPS module
Shock isolation mounting
Internal Switches / Jumpers
4 position DIP switch (SW1)
GPIO configuration jumpers
Reset Pushbutton
Test Pushbutton
