AIM SmartyCam CAN
Revision as of 22:32, 14 April 2016 by Brentp (talk | contribs) (→Integration Script: added script for extended channels)
This CAN bus integration maps CAN bus data from AIM systems normally directed to AIM's SmartyCam camera system.
Since the SmartyCam protocol is standard across AIM products, connecting RaceCapture/Pro to the CAN interface of an AIM product compatible with SmartyCam, communications can be intercepted and data can be mapped to RaceCapture/Pro telemetry channels.
Pictures
CAN database
AIM SmartyCAM CAN protocol
Integration Script
tickRate = 30
--the CAN baud rate
CAN_baud = 1000000
CAN_chan = 0
be_mode = 0
oilPresId = addChannel("OilPress", 10, 2, 0, 10, 'B')
temp1Id = addChannel ("Temp1" , 1, 0, 0, 170, 'C')
temp2Id = addChannel ("Temp2" , 1, 0, 0, 170, 'C')
ch1Id = addChannel ("Ch1", 1, 0, 0, 170, "C")
ch2Id = addChannel ("Ch2", 1, 0, 0, 170, "C")
ch3Id = addChannel ("Ch3", 1, 0, 0, 170, "C")
ch4Id = addChannel ("Ch4", 1, 0, 0, 170, "C")
ch5Id = addChannel ("Ch5", 1, 0, 0, 170, "C")
ch6Id = addChannel ("Ch6", 1, 0, 0, 170, "C")
ch7Id = addChannel ("Ch7", 1, 0, 0, 170, "C")
fuelPresId = addChannel ("FuelPress", 10, 2, 0, 10, "B")
CAN_map = {
[1059] = function(data) map_chan(ch4Id, data, 0, 2, 1, 0) map_chan(ch5Id, data, 2, 2, 0.01, 0) map_chan(ch6Id, data, 4, 2, 0.01, 0) map_chan(ch7Id, data, 6, 2, 0.01, 0) end,
    processCAN(CAN_chan)
function processCAN(chan)
    repeat
            local map = CAN_map[id]
            if map ~= nil then
                map(data)
    until id == nil
    offset = offset + 1
    local value = 0
    local shift = 1
    while len > 0 do
        shift = shift * 256
        offset = offset + 1
        len = len - 1
    offset = offset + 1
    local value = 0
    while len > 0 do
        offset = offset + 1
        len = len - 1
initCAN(CAN_chan, CAN_baud)
