AIM SmartyCam CAN
Connecting to the AIM system
| BMW E46 (including M3) | ||||||
| Connection | AIM Pin | RaceCapture/Pro Pin | ||||
| CAN High | 1 | 2 | ||||
| CAN Low | 4 | 3 | ||||
| Ground | 2 | 1 | ||||
Integration Script
tickRate = 30
--the CAN baud rate
CAN_baud = 1000000
CAN_chan = 0
be_mode = 0
oilPresId = addChannel("OilPress", 10, 2, 0, 10, 'B')
temp1Id = addChannel ("Temp1" , 1, 0, 0, 170, 'C')
temp2Id = addChannel ("Temp2" , 1, 0, 0, 170, 'C')
ch1Id = addChannel ("Ch1", 1, 0, 0, 170, "C")
ch2Id = addChannel ("Ch2", 1, 0, 0, 170, "C")
ch3Id = addChannel ("Ch3", 1, 0, 0, 170, "C")
ch4Id = addChannel ("Ch4", 1, 0, 0, 170, "C")
ch5Id = addChannel ("Ch5", 1, 0, 0, 170, "C")
ch6Id = addChannel ("Ch6", 1, 0, 0, 170, "C")
ch7Id = addChannel ("Ch7", 1, 0, 0, 170, "C")
fuelPresId = addChannel ("FuelPress", 10, 2, 0, 10, "B")
CAN_map = {
[1059] = function(data) map_chan(ch4Id, data, 0, 2, 1, 0) map_chan(ch5Id, data, 2, 2, 0.01, 0) map_chan(ch6Id, data, 4, 2, 0.01, 0) map_chan(ch7Id, data, 6, 2, 0.01, 0) end,
processCAN(CAN_chan)
function processCAN(chan)
repeat
local map = CAN_map[id]
if map ~= nil then
map(data)
until id == nil
offset = offset + 1
local value = 0
local shift = 1
while len > 0 do
shift = shift * 256
offset = offset + 1
len = len - 1
offset = offset + 1
local value = 0
while len > 0 do
offset = offset + 1
len = len - 1
initCAN(CAN_chan, CAN_baud)
