Mini Cooper R50 R52 R5
Status
In development / verification phase. The Mini Cooper ECU and instrument cluster electronics are very similar to the E46, so this integration is adapted from the E46.
Things you'll need
- PosiTap insulation piercing taps (22 gauge)
- RJ 45 (Ethernet) cable, ~6ft
- RaceCapture/Pro with Bluetooth
- Android tablet
- 2002-2006 Mini Cooper (R50, R52, R53)
Estimated Time
2-3 hours, depending on level of wiring experience. The most time consuming part is locating and splicing the CAN, power and groud wires into the RJ45 cable.
CAN wires
- (VERIFY) Yellow/Red = CAN+ (high)
- (VERIFY) Yellow/Brown = CAN- (low)
They are a twisted pair in or attached to the main wiring harness under the driver's side dash above the dead pedal. The wires need to be tapped, not cut.
Tapping CAN wires
To tap into the wires, you'll first need to unravel the wire as the CAN+/CAN- pair are tightly wound. You'll want to have enough room for 2 fingers in between the wires.
Tapping the wires via Posi-taps (recommended) is easy. Pull the top off the Positap, place the wire in it and tighten.
Power and ground wiring
Best option OBD-II port power
Using the same cable used for the CAN bus connection you can tap into power on the OBD-II port, for a clean 4 wire connection
Connection | Mini Cooper | RaceCapture/Pro (RJ45 cable) |
+12v | (VERIFY) Yellow-Red (OBD-II connector) | Brown |
Ground | (VERIFY) Brown (OBD-II connector) | Orange/White |
CAN High | (VERIFY) Yellow/Red | Orange |
CAN Low | (VERIFY) Yellow/Brown | Green/White |
CAN Bus connection
- Orange: CAN1 High
- Green/white: CAN1 Low
- Brown: Power
- Orange/white: Ground
- Note: Verify your RJ45 cable has EIA T568B printed on the jacket; this will ensure the color codes match.
Use the following diagram:
Configure RaceCapture/Pro
Quick Start configuration
Download: Mini Cooper starter configuration (right-click, save-as)
To complete your configuration for lap timing and live streaming to Podium:
- Add your favorite race tracks for automatic detection
- Set your telemetry device id as provided by podium.live
Manual Setup
If you already have an existing, customized configuration, follow these steps to add Mini Cooper CAN bus integration.
- Rate is 500kb/s
- Do not enable OBD-II channels.
Add this script to the Scripting section:
Script
--This example configured for Mini Cooper CAN -- Automatically starts logging with engine 'on' (RPM triggered) --how frequently we poll for CAN messages tickRate = 30 --the CAN baud rate CAN_baud = 500000 --CAN channel to listen on. 0=first CAN channel, 1=second CAN_chan = 0 --add your virtual channels here --format addChannel(<name>, <sample rate>, <precision>, <min>, <max>, [units]) tpsId = addChannel("TPS", 10, 0, 0, 100, "%") tempId = addChannel("EngineTemp", 1, 0, 0, 255, "F") oilTempId = addChannel("OilTemp", 1, 0, 0, 255, "F") rpmId = addChannel("RPM", 10, 0, 0, 10000) steerId = addChannel("Steering", 10, 0, -360, 360, "Deg.") brakeId = addChannel("BrakeSw", 10, 0, 0, 1) brakePressId = addChannel("Brake", 10, 0, 0, 255, "Bar") clutchId = addChannel("Clutch", 10, 0, 0, 1) lfWheelId = addChannel("LFWheelSpd", 10, 0, 0, 200, "MPH") rfWheelId = addChannel("RFWheelSpd", 10, 0, 0, 200, "MPH") lrWheelId = addChannel("LRWheelSpd", 10, 0, 0, 200, "MPH") rrWheelId = addChannel("RRWheelSpd", 10, 0, 0, 200, "MPH") gearTempId = addChannel("GearboxTmp", 10, 0, 0, 400, "F") fuelId = addChannel("Fuel", 1, 0, 0, 100, "%") extTempId = addChannel("ExtTemp", 1, 0, 0, 120,"F") --Convert C to F function toF(value) return value * 1.8 + 32 end --TPS, correct your throttle here for true 100% function tpsFilter(value) return value + 0.0 end --only start logging / telemetry if engine is running function rpmFilter(value) if value > 500 then startLogging() else stopLogging() end return value end function brakeFilter(value) return bit.rshift(bit.band(value, 0x10), 4) end function clutchFilter(value) return bit.band(value, 0x01) end function processWheel(id, data, offset) --wheel speed is 13 bits long, little endian --low byte high byte --76543210 76543210 --11111111 11111XXX local highByte = bit.band(data[offset + 2], 0x1F) local lowByte = data[offset + 1] local value = highByte * 256 + lowByte value = value * 0.0625 --convert to MPH. comment to keep KPH value = value * 0.621371 setChannel(id, value) end function processSteering(data) local steer = 0 if data[2] > 127 then steer = -1*(((data[2]-128)*256)+data[1]) else steer = (data[2]*256)+data[1] end setChannel(steerId, (steer*0.045)) end function fuelFilter(value) --adjust for 7 bit value value = bit.band(value, 0x7F) --convert liters to % return value / 0.48 end function extTempFilter(value) local temp = bit.band(value, 0x7F) if value > 127 then temp = -1 * temp end temp = toF(temp) return temp end ---------------------------------------- --customize here for CAN channel mapping --format is: --[CAN Id] = function(data) map_chan(<chan_id>, <data>, <CAN offset>, <CAN length>, <multiplier>, -- <adder>, [filter]) ---------------------------------------- CAN_map = { [496] = function(data) processWheel(lfWheelId, data, 0) processWheel(rfWheelId, data, 2) processWheel(lrWheelId, data, 4) processWheel(rrWheelId, data, 6) end, [339] = function(data) map_chan(brakeId, data, 0, 1, 1, 0, brakeFilter) end, [504] = function(data) map_chan(brakePressId, data, 2, 1, 1, 0) end, [809] = function(data) map_chan(tpsId, data, 5, 1 , 0.392156863, 0, tpsFilter) map_chan(tempId, data, 1, 1, 0.75, -48, toF) map_chan(clutchId, data, 3, 1, 1, 0, clutchFilter) end, [1349] = function(data) map_chan(oilTempId, data, 4, 1, 1, -48, toF) end, [1083] = function(data) map_chan(gearTempId, data, 0, 1, 1, -55, toF) end, [790] = function(data) map_chan(rpmId, data, 2, 2, 0.15625, 0, rpmFilter) end, [501] = function (data) processSteering(data) end, [1555] = function (data) map_chan(fuelId, data, 2, 1, 1, 0, fuelFilter) end, [1557] = function (data) map_chan(extTempId, data, 3, 1, 1, 0, extTempFilter) end } function onTick() processCAN(CAN_chan) end --===========do not edit below=========== function processCAN(chan) local msg = 0 repeat local id, e, data = rxCAN(chan, 0) if id ~= nil then local map = CAN_map[id] if map ~= nil then map(data) end end msg = msg + 1 until id == nil or msg > 100 end --Map CAN channel, little endian format function map_chan(cid, data, offset, len, mult, add, filter) if offset + len > #data then return end offset = offset + 1 local value = 0 local shift = 1 while len > 0 do value = value + (data[offset] * shift) shift = shift * 256 offset = offset + 1 len = len - 1 end local cv = value * mult + add if filter ~= nil then cv = filter(cv) end setChannel(cid, cv) end initCAN(CAN_chan, CAN_baud) setTickRate(tickRate)
Test!
Real-Time Telemetry
Just 4 wires - Power, Ground, CAN+ and CAN- is needed to stream tons of data to Podium for monitoring engine, driver and suspension performance!
- If you don't see any data, verify all connections and splices.
- If everything is connected connect your laptop to RaceCapture/Pro, open the RaceCapture/App, go to the Scripting section, set Logging Level to debug and select 'Poll logfile'. Check the output for any errors relating to the Lua Script.
- If you're copying in the script file, ensure any existing script is erased first, do not append the script text to the existing script.
