Megasquirt CAN
Channels enabled:
- Engine RPM (RPM)
- Throttle Position (TPS)
- Air/Fuel Ratio (AFR)
Megasquirt Wiring
Megasquirt 2 V3
- CAN High - DB37 Pin 3 (SPR1)
- CAN Low - DB37 Pin 4 (SPR2)
Connection | RaceCapture/Pro (RJ45 cable) |
+12v | Brown |
Ground | Orange/White |
CAN 1 High | Orange |
CAN 1 Low | Green/White |
- Note: If you have RaceCapture/Pro powered through the terminal block and grounded at the same location, all you need to wire are the two CAN ligh/CAN low connections. You do not need to separately connect ground and power via the RJ45 port.
MS3 Pro
- CAN High: Pin 34
- CAN Low : Pin 33
Photos
Enable Megasquirt Dashboard Mode
Integration Script
Paste this entire script into the Scripting window of RaceCapture/Pro. Ensure any existing script is completely overwritten - do not append to an existing script.
--This example configured for Megasquirt Dashboard Mode --how frequently we poll for CAN messages tickRate = 30 --the CAN baud rate CAN_baud = 500000 --CAN channel to listen on. 0=first CAN channel, 1=second CAN_chan = 0 --1 for Big Endian (MSB) mode; 0 for Little Endian mode (LSB) be_mode = 1 --add your virtual channels here --addChannel(<name>, <sample rate>, [logging precision], [min], [max], [units label]) rpmId = addChannel("RPM", 10, 0, 0, 8000) tpsId = addChannel("TPS", 10, 0, 0, 100, "%") mapId = addChannel("MAP", 10, 0, 0, 105, "kPa") cltId = addChannel("Coolant", 1, 0, 0, 250, "F") afrId = addChannel("AFR", 10, 1, 0, 20) --customize here for CAN channel mapping --format is: [CAN Id] = function(data) map_chan(<channel id>, data, <CAN offset>, <CAN length>, <multiplier>, <adder>) CAN_map = { [1512] = function(data) map_chan(mapId, data, 0, 2, 0.1, 0) map_chan(rpmId, data, 2, 2, 1, 0) map_chan(cltId, data, 4, 2, 0.1, 0) map_chan(tpsId, data, 6, 2, 0.1, 0, filter_tps) end, [1514] = function(data) map_chan(afrId, data, 1, 1, 0.1, 0) end } function onTick() processCAN(CAN_chan) end function filter_tps(value) --filter out overflow if value > 100 then value = 0 end return value end --===========do not edit below=========== function processCAN(chan) repeat local id, e, data = rxCAN(chan) if id ~= nil then local map = CAN_map[id] if map ~= nil then map(data) end end until id == nil end --Map CAN channel, big endian format function map_chan(cid, data, offset, len, mult, add, filter) offset = offset + 1 local value = 0 while len > 0 do value = (value * 256) + data[offset] offset = offset + 1 len = len - 1 end local cv = value * mult + add if filter ~= nil then cv = filter(cv) end setChannel(cid, cv) end initCAN(CAN_chan, CAN_baud) setTickRate(tickRate)
