PE3 CAN
The following script integrates the Performance Electronics PE3 ECU.
Reference Documentation=
Supported Channels
This integration supports the following channels:
- RPM
- TPS (Throttle Position)
- InjectorPw (Injector Pulse Width)
- Ignition (Ignition Advance)
- Baro (Barometer)
- MAP (Manifold Absolute Pressure)
- Lambda
- IAT (Air inlet temperature)
- EngineTemp
Connect the PE3 CAN High / CAN Low to the corresponding CAN High / CAN Low on the RaceCapture/Pro CAN 1 channel. See the [CAN_Bus_Integration|CAN integration guide]] for wiring details.
- Note: The PE3 ECU is already terminated with a 120 ohm resistor.
CAN integration script
Copy and paste this script into the scripting window of RaceCapture/Pro. Ensure any existing script is removed.
-- RaceCapture/Pro CAN mapping for Performance Electronics PE3 ECU -- Automatically starts logging with engine 'on' (RPM triggered) -- see rpmFilter() function -- --how frequently we poll for CAN messages tickRate = 30 --the CAN baud rate CAN_baud = 250000 --CAN channel to listen on. 0=first CAN channel, 1=second CAN_chan = 0 --add your virtual channels here --format addChannel(<name>, <sample rate>, <precision>, <min>, <max>, [units]) rpmId = addChannel("RPM", 25, 0, 0, 10000) tpsId = addChannel("TPS", 25, 0, 0, 100, "%") fuelTimeId = addChannel("InjectorPw", 25, 2, 0, 30, "ms") ignId = addChannel("Ignition", 25, 0.1, -20, 100, "deg") baroId = addChannel("Baro", 1, 1, 0, 105, "kpa") mapId = addChannel("MAP", 25, 1, 0, 255, "kpa") lambdaId = addChannel("Lambda", 25, 3, -2, 2, "") iatId = addChannel("IAT", 25, 1, 0, 255, "F") tempId = addChannel("EngineTemp", 1, 0, 0, 255, "F") --only start logging / telemetry if engine is running function rpmFilter(value) if value > 500 then startLogging() else stopLogging() end return value end ---------------------------------------- --customize here for CAN channel mapping --format is: --[CAN Id] = function(data) map_chan(<chan_id>, <data>, <CAN offset>, <CAN length>, <multiplier>, -- <adder>, [filter]) ---------------------------------------- CAN_map = { [0x0CFFF048] = function(data) map_chan(rpmId, data, 0, 2, 1, 0, rpmFilter) map_chan_s(tpsId, data, 2, 2, 0.1, 0) map_chan_s(fuelTimeId, data, 4, 2, 0.01, 0) map_chan_s(ignId, data, 6, 2, 0.1, 0) end, [0x0CFFF148] = function(data) map_chan_s(baroId, data, 0, 2, 0.01, 0) map_chan_s(mapId, data, 2, 2, 0.01, 0) map_chan_s(lambdaId, data, 4, 2, 0.001, 0) end, [0x0CFFF548] = function(data) map_chan_s(iatId, data, 2, 2, 0.1, 0) map_chan_s(tempId, data, 4, 2, 0.1, 0) end } function onTick() processCAN(CAN_chan) end --===========do not edit below=========== function processCAN(chan) local msg = 0 repeat local id, e, data = rxCAN(chan, 0) if id ~= nil then local map = CAN_map[id] if map ~= nil then map(data) end end msg = msg + 1 until id == nil or msg > 100 end --Map CAN channel, little endian format function map_chan(cid, data, offset, len, mult, add, filter) if offset + len > #data then return end offset = offset + 1 local value = 0 local shift = 1 while len > 0 do value = value + (data[offset] * shift) shift = shift * 256 offset = offset + 1 len = len - 1 end local cv = value * mult + add if filter ~= nil then cv = filter(cv) end setChannel(cid, cv) end --Map CAN channel, little endian format function map_chan_s(cid, data, offset, len, mult, add, filter) if offset + len > #data then return end offset = offset + 1 local value = 0 local shift = 1 while len > 0 do value = value + (data[offset] * shift) shift = shift * 256 offset = offset + 1 len = len - 1 end --adjust for sign if value > 32767 then value = value - 65536 end local cv = value * mult + add if filter ~= nil then cv = filter(cv) end setChannel(cid, cv) end initCAN(CAN_chan, CAN_baud) setTickRate(tickRate)
