RaceCapture-Track
Revision as of 00:36, 16 November 2016 by Brentp (talk | contribs) (→System Status)
Start it up
Plug it in
Download the app
Navigating dashboard screens
  • When GPS receives a lock, RaceCapture will search for a known nearby track.
Setup Mode
You can configure RaceCapture simultaneously for both Access Point and Client mode.
Telemetry
Logs
Analysis Mode
Applying Decals
