RaceCapturePro2 QuickStart
Prerequisites
OSX:
  • No drivers are needed for OSX.
Windows 10:
  • No drivers are needed for Windows 10. Windows will automatically detect RaceCapture/Pro, and it will appear as a USB Serial device under Device Manager.
Windows XP, 7, 8:
Quick Start
Running the Application
  2. Click on 'Dashboard'
  4. Once the tracks have been selected, write the updated configuration using the Rc appwrite config.png button in the lower left.
ProTip: Periodically click the update button Update from cloud.png to pull down the latest set of race track configurations.
Manual track configuration
If the track is not listed, or if you have a specific or custom course you wish to run, then you can set a manual start/finish line.
Setting up Bluetooth
  • Complete the Quick Start steps above, leaving RaceCapture/Pro connected to your computer
  • Connect the Bluetooth module to the inner of the two RaceCapture/Pro ports on the same side the USB cable connects to
  • Open the Race Capture app
  • Click on the top left 'Menu' button
  • Click on 'Configuration'
  • Click on 'Wireless' in the list of options on the left
  • Click the toggle to the right of 'Bluetooth'
  • Click the 'Write Config' button on the bottom left (down array pointing to a RaceCapture/Pro)
Set up Android tablet/phone
App Download:
Requirements
  • Android 5 and higher
  • Quad core 1.3 GHz processor
  • 1 GB RAM, 8 GB flash
  • 7" to 10" screen
Primary recommendation
Lower end recommendation
Other tablet recommendations
You can use other higher quality tablets, such as models from Samsung, Google Lenovo and LG. Your mileage may vary. A few examples:
Bluetooth pairing
    3. Default password is 1234
  2. Install the Race Capture app on your Android device:
  1. Open the RaceCapture app. The RaceCapture app will search for the RaceCapturePro device
Verify connectivity
  1. Select the dashboard screen and switch to the raw channels view - you should see values updating in real-time.
Troubleshooting Bluetooth connection issues
  • Ensure RaceCapture/Pro is powered up and the Bluetooth module is plugged in to the inner RJ11 port, located to the right of the front panel push-button
  • Ensure Bluetooth is enabled in the wireless settings of the RaceCapture/Pro configuration
    • Note, you will need to connect via USB to verify this setting
  • Ensure Bluetooth is enabled under the Android Settings
    • On some tablets with a marginal or unstable Bluetooth support, a disable/re-enable of Bluetooth may help
  • Try un-pairing and re-pairing the RaceCapture/Pro Bluetooth device
  • Try re-starting the Android device
Logging Data to SD card
Logging Prerequisites
    • The card is installed with the label facing the top of the unit, metal contacts facing down
    • Note: We recommend a fresh format of the card before you first log data.
Logging Data
    • The filename will end in .log
    • The logfile is in plain CSV data format.
If you have problems logging data, try the following:
  • If there is a write protect switch on the card, ensure it is not set to 'read only'.
  • If you get random, corrupted data in the log file, try performing a clean FAT32 format of the SD card and try again. You can also try a different SD card.
  • If you see the red LED flicker or illuminate during logging, especially during high sample rates, try a different SD card, preferably a high quality, high speed card.
  • Enable the logging feature in the app (in the scripting view) to see any specific messages about logging, this may aid in troubleshooting.
Automatic logging control
