RacecapturePro MK3 hardware install
Revision as of 04:08, 25 March 2017 by Brentp (talk | contribs)
Orientation
Main Connector
The main connector provides access to all power, sensor and communications connections for the RaceCapture/Pro system.
Power
Connection Color
12v Red
Ground Black
Frequency / RPM sensor inputs
Blue Frequency / RPM input 1
Voltage Reference
Yellow +5v voltage reference
Analog Sensor Inputs
White Analog Input 1
Gray GPIO 1
Gray / White Stripe GPIO 2
Gray / Blue Stripe GPIO 3
Auxiliary Serial Input
CAN Bus
Orange CAN 1 Low
Plug Connector Type
  • Plug Housing: Molex Mini Fit Jr 39012240
  • Compatible Pins: Molex 46018-1541 or 46018-1541
  • ProTip: a 24 pin Molex harness from a computer power supply can also work as a secondary wiring harness
Cellular Telemetry
Antenna Placement Guide
Cellular antenna
Antenna separation
RJ45 CAN + Power connection
OBDII CAN cable
Custom Cable
+12v Brown
Ground Orange/White
CAN 1 High Orange
CAN 1 Low Green/White
CAN 2 High Blue
CAN 2 Low Blue/White
Analog Sensor inputs
GPIO
Input Mode
Output Mode
Communications
CAN Channels 1 / 2
Auxiliary Serial
