ShiftX2
(Introduction about ShiftX2)
Scripts
Disco Lights Demo
Script
Copy and paste this entire script into the Scripting window, replacing any existing script.
Script
Script
Boost Gauge
Script
Only Alerts
- Left alert for oil pressure
Script
ShiftX2 starter script
ShiftX2 CAN bus API
CAN base ID is 744389
If the device supports hardware configurable ID offsets, such as via DIP switches or breakable jumpers, each incremental offset will add 1000 to the base ID.
| Offset | What | Value |
Reset Device
CAN ID: Base + 1
| (no data) | ||
| (no data) | ||
| 0 | Brightness | 0 - 100 (0=automatic brightness) |
Set Discrete LED
CAN ID: Base + 10
| 2 | Red | 0 - 255 |
| 3 | Green | 0 - 255 |
| 4 | Blue | 0 - 255 |
Alert Indicators
Set Alert
CAN ID: Base + 11
| 1 | Red | 0 - 255 |
| 2 | Green | 0 - 255 |
| 3 | Blue | 0 - 255 |
Set Alert Threshold
- Alerts are processed in descending order by alert ID and will be handled by the first threshold the current value exceeds.
CAN ID: Base + 12
| 1 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
| 5 | Green | 0 - 255 |
| 6 | Blue | 0 - 255 |
Update Current Alert Value
CAN ID: Base + 13
| 1 | Value (low byte) | |
| 2 | Value (high byte) |
Linear Graph
- Linear style: stepped
- Low Range: 0
- High Range: N/A
- Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 14
Set Linear Graph Threshold
CAN ID: Base + 15
| 0 | Threshold ID | 0 - 4 |
| 4 | Red | 0 - 255 |
CAN ID: Base + 16
