How To Update Firmware
Revision as of 05:41, 14 June 2017 by Brentp (talk | contribs)
RaceCapture/Pro MK2 / MK3 / RaceCapture/Apex
Save your configuration
Download the firmware
  • Note Ensure you download the correct firmware for your device, or the firmware process will fail to complete.
Flash the firmware
Alternative method
Problems? Post to the forums with the issue you're seeing - we will help you promptly.
RaceCapture/Pro MK1
Alternatively:
Mac Users
