ShiftX2
(Introduction about ShiftX2)
Scripts
Disco Lights Demo
Script
--implement me
Script
--implement me
Script
--implement me
Boost Gauge
Script
--implement me
Only Alerts
  • Left alert for oil pressure
Script
--implement me
ShiftX2 starter script
--what CAN bus ShiftX2 is connected to. 0=CAN1, 1=CAN2
sxCan=0
--primary or secondary ShiftX2 on CAN bus. 0=primary, 1=secondary
sxId=0
--brightness. 1-100% or 0 for auto brightness
sxBright=0
--tick rate in Hz. How often ShiftX2 is updated.
tickRate=30
function sxOnUpdate()
  --Update ShiftX2 from your sensor values here
function sxOnBut(data)
  --add your button handler code here
  println('button: ' ..data[1])
--Setup ShiftX2 here
function sxOnInit()
  --add your ShiftX2 setup here
  println('ShiftX2 Init')
---ShiftX2 functions---
--red: Red value (0-255)
--green: Green value (0-255)
--blue: Blue value (0-255)
--alertId: Alert Id to set
--currentValue: Updated value
--Configures the linear graph
  sxTx(3,{bright})
function setAlert(id,r,g,b,f)
  sxTx(20,{id,r,g,b,f})
function updateAlert(id,v)
function updateLinearGraph(v)
  sxTx(42,{spl(v),sph(v)})
function sxInit()
  println('config shiftX2')
  setBaseConfig(sxBright)
function sxChkCan()
  id,ext,data=rxCAN(sxCan,0)
function sxProcess()
  sxChkCan()
function sxTx(offset, data)
  sleep(10)
  sxProcess()
sxInit()
ShiftX2 CAN bus API
If the device supports hardware configurable ID offsets, such as via DIP switches or breakable jumpers, each incremental offset will add 256 to the base ID.
Offset What Value
Reset Device
CAN ID: Base + 1
Offset What Value
(no data)
Offset What Value
Offset What Value
0 Brightness 0 - 100; default = 0 (0=automatic brightness)
1 Automatic brightness scaling (Optional) 0-255; default=51
Set Discrete LED
CAN ID: Base + 10
Offset What Value
2 Red 0 - 255
3 Green 0 - 255
4 Blue 0 - 255
5 Flash 0-10Hz (0 = full on)
Alert Indicators
Set Alert
CAN ID: Base + 20
Offset What Value
1 Red 0 - 255
2 Green 0 - 255
3 Blue 0 - 255
4 Flash 0-10Hz (0 = full on)
Set Alert Threshold
  • Threshold value must be > 0 to be valid
  • Alerts are processed in descending order by Threshold ID, where:
    • The threshold is selected where the threshold is > 0 and current value is >= threshold and < than the next threshold
    • If the current value is less than the first threshold, then the alert indicator is disabled.
CAN ID: Base + 21
Offset What Value
1 Threshold ID 0 - 4
2 Threshold (low byte)
3 Threshold (high byte)
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
Update Current Alert Value
CAN ID: Base + 22
Offset What Value
1 Value (low byte)
2 Value (high byte)
Linear Graph
  • Linear style: stepped
  • Low Range: 0
  • High Range: N/A
  • Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Offset What Value
2 Low Range (low byte)
3 Low Range (high byte)
Set Linear Graph Threshold
CAN ID: Base + 41
Offset What Value
0 Threshold ID 0 - 4
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
CAN ID: Base + 42
Offset What Value
0 Value (low byte)
1 Value (high byte)
Notifications
Button State
CAN ID: Base + 60
Offset What Value
