ShiftX2
Assembling the enclosure
((picture))
((picture))
  • Place ShiftX2 onto the bottom layer, and stack the 1/4" middle frame on top, with the clearance notch over the connector.
((picture))
  • Place the top clear cover onto ShiftX2, with the hole for the button on the left side.
((picture))
Mounting ShiftX2
Pinout
Color Assignment Notes
Red 5-12v Power Connect this to switched ignition power. 0.5A max consumption.
Black CAN High
Yellow CAN Low
Black Ground
Scripts
Disco Lights Demo
Script
sxCan = 0
sxId=0
tickRate=30
sxBright=0
function rndc()
  return math.random(0,255)
function sxOnUpdate()
  for i=0,9,1 do
    r = rndc()
    g = rndc()
    b = rndc()
	sxSetLed(i,1,r,g,b,0)
function sxOnBut(d)
  println('button: ' ..d[1])
function sxOnInit()
  print('sx onInit')
--ShiftX2 library functions--
function sxSetLed(id,l,r,g,b,f)
  sxTx(10,{id,l,r,g,b,f})
  sxTx(3,{bright})
function setAlert(id,r,g,b,f)
  sxTx(20,{id,r,g,b,f})
function updateAlert(id,v)
function updateLinearGraph(v)
  sxTx(42,{spl(v),sph(v)})
function sxInit()
  println('config shiftX2')
  setBaseConfig(sxBright)
function sxChkCan()
  id,ext,data=rxCAN(sxCan,0)
function sxProcess()
  sxChkCan()
function sxTx(offset, data)
  sleep(10)
  sxProcess()
sxInit()
Script
--implement me
Script
--implement me
Boost Gauge
Script
--implement me
Only Alerts
  • Left alert for oil pressure
Script
--implement me
ShiftX2 starter script
---ShiftX2 functions---
--Set an individual LED
--red: Red value (0-255)
--green: Green value (0-255)
--blue: Blue value(0-255)
--blue: Blue value (0-255)
--alertId: Alert Id to set
--currentValue: Updated value
--Configures the linear graph
--End reference
  sxTx(10,{i,l,r,g,b,f})
  sxTx(3,{bright})
function sxInit()
function sxChkCan()
  sxChkCan()
  sleep(10)
  sxProcess()
sxInit()
ShiftX2 CAN bus API
Offset What Value
Reset Device
CAN ID: Base + 1
Offset What Value
(no data)
Offset What Value
Offset What Value
0 Brightness 0 - 100; default = 0 (0=automatic brightness)
1 Automatic brightness scaling (Optional) 0-255; default=51
Set Discrete LED
CAN ID: Base + 10
Offset What Value
2 Red 0 - 255
3 Green 0 - 255
4 Blue 0 - 255
5 Flash 0-10Hz (0 = full on)
Alert Indicators
Set Alert
CAN ID: Base + 20
Offset What Value
1 Red 0 - 255
2 Green 0 - 255
3 Blue 0 - 255
4 Flash 0-10Hz (0 = full on)
Set Alert Threshold
  • Threshold value must be > 0 to be valid
  • Alerts are processed in descending order by Threshold ID, where:
    • The threshold is selected where the threshold is > 0 and current value is >= threshold and < than the next threshold
    • If the current value is less than the first threshold, then the alert indicator is disabled.
CAN ID: Base + 21
Offset What Value
1 Threshold ID 0 - 4
2 Threshold (low byte)
3 Threshold (high byte)
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
Update Current Alert Value
CAN ID: Base + 22
Offset What Value
1 Value (low byte)
2 Value (high byte)
Linear Graph
  • Linear style: stepped
  • Low Range: 0
  • High Range: N/A
  • Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
Offset What Value
2 Low Range (low byte)
3 Low Range (high byte)
Set Linear Graph Threshold
CAN ID: Base + 41
Offset What Value
0 Threshold ID 0 - 4
4 Red 0 - 255
5 Green 0 - 255
6 Blue 0 - 255
CAN ID: Base + 42
Offset What Value
0 Value (low byte)
1 Value (high byte)
Notifications
Button State
CAN ID: Base + 60
Offset What Value
