ShiftX2
In the kit you will receive:
- ShiftX2 module
- 4 wire pigtail
- Acrylic enclosure
Assembling the enclosure
Mounting ShiftX2
Pinout
Color | Assignment | Notes |
Red | 5-12v Power | Connect this to switched ignition power. 0.5A max consumption. |
Black | CAN High | |
Yellow | CAN Low | |
White | Ground |
Power
CAN bus connections
Scripts
Disco Lights Demo
Script
sxCan = 0 sxId=0 tickRate=30 sxBright=0 function rndc() return math.random(0,255) end function sxOnUpdate() for i=0,9,1 do r = rndc() g = rndc() b = rndc() sxSetLed(i,1,r,g,b,0) end end function sxOnBut(b) println('button: ' ..b) end function sxOnInit() print('sx onInit') end --ShiftX2 library functions-- function sxSetLed(i,l,r,g,b,f) sxTx(10,{i,l,r,g,b,f}) end function sxSetLinearThresh(id,s,th,r,g,b,f) sxTx(41,{id,s,spl(th),sph(th),r,g,b,f}) end function sxSetAlertThresh(id,tid,th,r,g,b,f) sxTx(21,{id,tid,spl(th),sph(th),r,g,b,f}) end function sxSetBaseConfig(bright) sxTx(3,{bright}) end function sxSetAlert(id,r,g,b,f) sxTx(20,{id,r,g,b,f}) end function sxUpdateAlert(id,v) if v~=nil then sxTx(22,{id,spl(v),sph(v)}) end end function sxCfgLinearGraph(rs,ls,lr,hr) sxTx(40,{rs,ls,spl(lr),sph(lr),spl(hr),sph(hr)}) end function sxUpdateLinearGraph(v) sxTx(42,{spl(v),sph(v)}) end function sxInit() println('config shiftX2') sxSetBaseConfig(sxBright) if sxOnInit~=nil then sxOnInit() end end function sxChkCan() id,ext,data=rxCAN(sxCan,0) if id==sxCanId then sxInit() end if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1]) end end function sxProcess() sxChkCan() if sxOnUpdate~=nil then sxOnUpdate() end end function sxTx(offset, data) txCAN(sxCan, sxCanId + offset, 1, data) sleep(10) end function spl(v) return bit.band(v,0xFF) end function sph(v) return bit.rshift(bit.band(v,0xFF00),8) end function onTick() sxProcess() end sxCanId = 0xE3600 + (256 * sxId) println('shiftx2 base id ' ..sxCanId) setTickRate(tickRate) sxInit()
Script
Script
Boost Gauge
Script
Only Alerts
- Left alert for oil pressure
Script
ShiftX2 starter script
-- What CAN bus ShiftX2 is connected to. 0=CAN1, 1=CAN2 sxCan = 0 -- 0=first ShiftX2 on bus, 1=second ShiftX2 (if ADR1 jumper is cut) sxId=0 --how often ShiftX2 is updated tickRate=30 --Brightness, 0-100. 0=automatic brightness sxBright=0 function sxOnUpdate() --add your code to update ShiftX2 alerts or linear graph during run time. --Runs continuously based on tickRate. end function sxOnInit() --add your code for configuring ShiftX2. Runs once during startup end function sxOnBut(b) --called if the button state changes println('button: ' ..b) end ---ShiftX2 functions --=============== --Reference. Delete me to save space --=============== --function sxSetLed(index,length,red,green,blue,flash) --Set an individual LED --index: LED index, starting at 0 --length: number of LEDs to set at once --red: Red value (0-255) --green: Green value (0-255) --blue: Blue value(0-255) --flashHz: Flash rate, in Hz; 0=no flash --sxSetLinearThresh(thresholdId,segmentLength,thresholdValue,red,green,blue,flashHz) --Setup a threshold for the linear graph --thresholdId: Threshold ID to set. from 0-4. define in ascending order. --segmentLength: Length of the segment when in stepped graph mode. ignored for smooth mode. --thresholdValue: Value for this threshold. --red: Red value (0-255) --green: Green value (0-255) --blue: Blue value (0-255) --flashHz: Flash rate, in Hz; 0=no flash --sxSetAlertThresh(alertId,thresholdId,thresholdValue,red,green,blue,flashHz) --Setup a threshold for an alert indicator --alertId: Id of the alert to configure --thresholdId: Threshold ID to set. from 0-4. define in ascending order. --thresholdValue: Value for this threshold. --red: Red value (0-255) --green: Green value (0-255) --blue: Blue value (0-255) --flashHz: Flash rate, in Hz; 0=no flash --sxSetAlert(alertId,red,green,blue,flashHz) --Directly sets an alert indicator --alertId: Alert Id to set --red: Red value (0-255) --green: Green value (0-255) --blue: Blue value (0-255) --flashHz: Flash rate, in Hz; 0=no flash --sxUpdateAlert(alertId,currentValue) --Updates Current alert value, using the previously configured thresholds --alertId: Alert Id to set --currentValue: Updated value --sxCfgLinearGraph(renderStyle,linearStyle,lowRange,highRange) --Configures the linear graph --renderStyle: 0=left->right, 1=center,2=right->left --linearStyle: 0=smooth/interpolated, 1=stepped --lowRange: low range of the graph --highRange: high range of the graph (ignored if stepped linear style) --sxUpdateLinearGraph(currentValue) --Updates the linear graph value, using the previously configured thresholds --currentValue: Updated value --=============== --End reference --=============== function sxSetLed(i,l,r,g,b,f) sxTx(10,{i,l,r,g,b,f}) end function sxSetLinearThresh(id,s,th,r,g,b,f) sxTx(41,{id,s,spl(th),sph(th),r,g,b,f}) end function sxSetAlertThresh(id,tid,th,r,g,b,f) sxTx(21,{id,tid,spl(th),sph(th),r,g,b,f}) end function setBaseConfig(bright) sxTx(3,{bright}) end function sxSetAlert(id,r,g,b,f) sxTx(20,{id,r,g,b,f}) end function sxUpdateAlert(id,v) if v~=nil then sxTx(22,{id,spl(v),sph(v)}) end end function sxCfgLinearGraph(rs,ls,lr,hr) sxTx(40,{rs,ls,spl(lr),sph(lr),spl(hr),sph(hr)}) end function sxUpdateLinearGraph(v) sxTx(42,{spl(v),sph(v)}) end function sxInit() println('config shiftX2') setBaseConfig(sxBright) if sxOnInit~=nil then sxOnInit() end end function sxChkCan() id,ext,data=rxCAN(sxCan,0) if id==sxCanId then sxInit() end if id==sxCanId+60 and sxOnBut~=nil then sxOnBut(data[1]) end end function sxProcess() sxChkCan() if sxOnUpdate~=nil then sxOnUpdate() end end function sxTx(offset, data) txCAN(sxCan, sxCanId + offset, 1, data) sleep(10) end function spl(v) return bit.band(v,0xFF) end function sph(v) return bit.rshift(bit.band(v,0xFF00),8) end function onTick() sxProcess() end sxCanId = 0xE3600 + (256 * sxId) println('shiftx2 base id ' ..sxCanId) setTickRate(tickRate) sxInit()
ShiftX2 CAN bus API
Offset | What | Value |
Reset Device
CAN ID: Base + 1
(no data) |
0 | Brightness | 0 - 100; default = 0 (0=automatic brightness) |
1 | Automatic brightness scaling (Optional) | 0-255; default=51 |
Set Discrete LED
CAN ID: Base + 10
2 | Red | 0 - 255 |
3 | Green | 0 - 255 |
4 | Blue | 0 - 255 |
Alert Indicators
Set Alert
CAN ID: Base + 20
1 | Red | 0 - 255 |
2 | Green | 0 - 255 |
3 | Blue | 0 - 255 |
Set Alert Threshold
- Alerts are processed in descending order by Threshold ID, where:
- The threshold is selected where the threshold is > 0 and current value is >= threshold and < than the next threshold
- If the current value is less than the first threshold, then the alert indicator is disabled.
CAN ID: Base + 21
1 | Threshold ID | 0 - 4 |
2 | Threshold (low byte) | |
3 | Threshold (high byte) | |
4 | Red | 0 - 255 |
5 | Green | 0 - 255 |
6 | Blue | 0 - 255 |
Update Current Alert Value
CAN ID: Base + 22
1 | Value (low byte) | |
2 | Value (high byte) |
Linear Graph
- Linear style: stepped
- Low Range: 0
- High Range: N/A
- Threshold :
Configure Linear Graph
Rendering style:
Linear style:
CAN ID: Base + 40
2 | Low Range (low byte) | |
3 | Low Range (high byte) | |
Set Linear Graph Threshold
CAN ID: Base + 41
0 | Threshold ID | 0 - 4 |
4 | Red | 0 - 255 |
CAN ID: Base + 42
0 | Value (low byte) | |
1 | Value (high byte) |
Notifications
Button State
CAN ID: Base + 60
